Author Topic: Door pillar trim  (Read 2296 times)
Offline bill88
Door pillar trim
« on: 26 January 2010, 18:11 »
Drivers side rear speaker stopped working last week,i traced the fault to a break in the wiring where the round/twisty block connector is on the door pillar.I've managed to repair the broken wire,but when i went to twist the block connector back on the piece that is attached to door pillar fell into the door pillar,ive now spent the last two hours trying to pull it back through,but have only succeeded in removing skin from my knuckles and having a mini nervous breakdown  :cry:
I've decided to try and source another from a breakers yard,but cant figure out how to remove the trim from the inside of the pillar.I've removed the screw at the top,but apart from sliding upwards an inch,the trim wont come off.Please,please,please can someone explain how i remove the inner trim from the door pillar without resorting to a crow bar. :sad: :sad:
Offline VR6-Joe
Re: Door pillar trim
« Reply #1 on: 26 January 2010, 18:36 »
Is this the white circular block that the door wiring loom screws into?
If so, I don't recall any screws being there, but get your head inside the car and have a look up at the back of it and there's a few clips that hold it in I do believe. I've removed these and refitted them several time with no problems.
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline bill88
« Reply #2 on: 26 January 2010, 18:41 »
Thats the fella,but its the trim i need to remove so i can get at the back of the door pillar to clip the circular piece back on.I've removed the section of trim at the top where the seat belt goe's through,but i cant figure out how to remove the main piece of pillar trim.
Offline VR6-Joe
« Reply #3 on: 26 January 2010, 18:48 »
Ahhh, your car is 5dr so you're on about the B pillar trim, I thought you were on about the A pillar :sad:
I'm afraid I've only ever had 3dr Golfs (5 of them actually lol) so I can't help you :sad:
Offline bill88
« Reply #4 on: 26 January 2010, 19:11 »
Thanks anyway.
Offline axewielder
  • 95 dragon 8v
« Reply #5 on: 26 January 2010, 20:55 »
on my mk 4 that was a right pain to get off, lots of brute force, but no quite enough to break anything, as it quite often is with vw trim  :angry: i know the mini nervous breakdown you speak of, i think we all do! just be careful+ double check everywhere for hiden screws
Offline bill88
« Reply #6 on: 26 January 2010, 21:55 »
Can somebody/anybody please help ? :cry: i have to try and sort this tomorrow as i'm back at work thursday.Thanks in advance.
Offline bill88
« Reply #7 on: 27 January 2010, 12:09 »
 :smiley: :smiley: All sorted.For anyone attempting the same job in the future remove top screw in centre of trim then pull at the edges and not in the middle as i had tried.The trim hooks around the door rubbers and once you get one cormer moving it literally peels off.
