Author Topic: Mk2 gti 16v in Mk3 **Info Please**  (Read 3500 times)
Offline hudmk3
« on: 24 January 2010, 21:31 »
Help Please!
Building a project on a SMALL budget!! Have picked up a 96 3dr Mk3 SE with 1.8 ADZ engine for next to nothing. tis a little gutless!!  I have chance to get MK2 gti 16v engine (KR?) and box for v reasonable price. I want to drop this into the mk3. Will it go straight in? What will i need to mod? Take it I'll need the Mk2 loom, ECU, and exhaust? Will the pedals etc from the mk3 be ok? Clocks? Any tips on buying the 16v lump? Average prices - signs to look for etc
1st project guys so any help/input/digs appreciated
Thanks :wink:
Hudders
Offline Cable
Re: Mk2 gti 16v in Mk3 **Info Please**
« Reply #1 on: 24 January 2010, 21:35 »
I think the mk2 has a completly different fueling system, if you can get an abf will be easier and more powerful engine.
« Reply #2 on: 24 January 2010, 21:36 »
Not going to work without major work, your car is single point injection, KR is k jet so fuel system will be a nightmare plus the brakes will need uprating.
Offline Cable
« Reply #3 on: 24 January 2010, 21:38 »
if you have a small budget, the 8v gti 2.0 will be alot cheaper and easier to fit.
Offline hudmk3
« Reply #4 on: 24 January 2010, 21:43 »
Will the 2.0 8v slip in relatively easy then?
Ta
« Reply #5 on: 24 January 2010, 21:44 »
Ta
Yes but you will need a donor car really as you will need wiring lom and ecu plus brakes etc, also you will only gain 25bhp.
Offline Cable
« Reply #6 on: 24 January 2010, 21:48 »
Ta
Yes but you will need a donor car really as you will need wiring lom and ecu plus brakes etc, also you will only gain 25bGp
Offline hudmk3
« Reply #7 on: 24 January 2010, 21:52 »
Might have rethink then!
May just MOT it fix the bare minimum and sell it and wait for a decent 16v spares or repair to do. More door 16v one went today for £460.
Anyone seen ones go any less?
Offline Cable
« Reply #8 on: 24 January 2010, 21:55 »
without mot i think ive seen one go fo aound £300 and the 16v engine is alot better than the 8v. So if i were u just ddo what you sed and get the 16v
« Reply #9 on: 24 January 2010, 23:39 »
Don't believe the hype, 16v is not much better than a 8v
