Author Topic: track rod end rubber cover?  (Read 1501 times)
Offline rachsgolf
« on: 24 January 2010, 14:15 »
is a 3mm split in one a mot failure?
cheers
Offline Tuccy
Re: track rod end rubber cover?
« Reply #1 on: 24 January 2010, 14:19 »
technicially speaking yes its a fail
really depends on your examiner on the day tho,
ive had worse pass
but ive also had less fail
all depends what side of bed your examiner got out of that day lol :rolleyes:
« Reply #2 on: 24 January 2010, 14:39 »
Yes it should fail
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 24 January 2010, 15:00 »
It should fail as it will let dirt/grit inside causing failure....I would change a.s.a.p my self
Offline AudiA8Quattro
« Reply #4 on: 24 January 2010, 16:37 »
No, its only an advisory.
Only excess play is a failure.
Offline madgti
« Reply #5 on: 24 January 2010, 16:41 »
+1
« Reply #6 on: 24 January 2010, 16:41 »
Steering components:-
Components enclosed by gaiters
Because dismantling is not permitted, it is accepted that visual examination of some components which are enclosed by protective gaiters will not be possible.
Method of inspection
b. relative movement between sector shaft and drop arm
c. loose ball pin shanks
d. loose track rod end or drag link ends
e. weak or broken socket springs
f. excessive play in ball joints
Reason for rejection
b. relative movement between the sector shaft and the drop arm
c. a loose ball pin shank
d. a loose track rod or drag link end e. a weak or broken socket spring
f. excessive play in a ball joint
Offline opel
« Reply #7 on: 24 January 2010, 18:49 »
no not fail aslong as there aint play in it they would only advise andyou would replace it in end due to it knackering joint
