Author Topic: vr6 exhaust  (Read 2320 times)
Offline whiter_than_white
  • Seize the day or die regretting the time you lost!
vr6 exhaust
« on: 24 January 2010, 12:32 »
just a quick query, will a vr6 exhaust (de-cat, middle and back) fit my 96 8v gti??
Re: vr6 exhaust
« Reply #1 on: 24 January 2010, 12:52 »
It will need reducing down.
Re: vr6 exhaust
« Reply #2 on: 24 January 2010, 13:16 »
what if i just went cat back??
Offline Andy-H
Re: vr6 exhaust
« Reply #3 on: 24 January 2010, 13:21 »
When I put a Powerflow cat-back on my old 8v, that was off a VR6 and didn't need a reducer but I'd say the best thing to do is measure your current pipe against the one you are wanting to put on  :smiley:.
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
Re: vr6 exhaust
« Reply #4 on: 24 January 2010, 13:27 »
the one i'm looking at buying is a magnex one but wont be able to measure until ive bought it :( thats why i thought id ask first before spending the cash to find out it wont fit and need to spend more
Offline boneybradley
  • Back in a Mk3...
Re: vr6 exhaust
« Reply #5 on: 24 January 2010, 13:51 »
from the rear of the cat it will have a small connector pipe and if this is changed to the the correct size, any exhaust will fit (mine had a 16v/vr6 exhaust fitted by using an early 16v connector)
Re: vr6 exhaust
« Reply #6 on: 24 January 2010, 14:56 »
so will the connector pipe be on my car or is it something i will need to buy??
  • Back in a Mk3...
Re: vr6 exhaust
« Reply #7 on: 24 January 2010, 14:59 »
you'll need to buy...find a timax or bosal dealer and have a look in their book as this will show what's possible to use
Re: vr6 exhaust
« Reply #8 on: 24 January 2010, 15:09 »
cheers bradley, we use a local motor factors a lot thru work and i'm sure we've got an exhuast book so i'll have a look thru and see what they got, cheers
  • Back in a Mk3...
Re: vr6 exhaust
« Reply #9 on: 24 January 2010, 15:15 »
Going off memory I'm sure the 8v uses the same cat as the early 16v and it's that models short connector pipe you need to use the 16v/vr6 downpipe
