Author Topic: Double din radio help  (Read 2767 times)
Offline golf-sib
  • Турботазик
« on: 23 January 2010, 15:30 »
My new double din unit does not have a radio female plug, it does have a:
Radio Vcc
Gnd Power
Im guessing I strip the old plug down and just a electricians block to join them together?
Many Thanks in advance
Alex
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline troublestarter
Re: Double din radio help
« Reply #1 on: 23 January 2010, 16:44 »
don't chop your car loom you will regret it
i can send you a female iso plug £5.00 delivered if you like
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline golf-sib
  • Турботазик
« Reply #2 on: 23 January 2010, 16:57 »
Thanks, I just poped down the local audio shop and got the connector, I do have a new problem, on the standard iso-loom when I take the key out, I loose all power and all my headunit settings reset, anyway of sorting this out, my old sony one had the same problem?
1.8T AGU..
R135
  24
« Reply #3 on: 23 January 2010, 17:02 »
swap the yellow and red over problem solved
Offline golf-sib
  • Турботазик
« Reply #4 on: 23 January 2010, 17:12 »
On what precisely, im a noob when it comes to headunits lol
1.8T AGU..
R135
  24
« Reply #5 on: 23 January 2010, 17:38 »
on the stereo loom you should have a red and a yellow wire
connect the red coming from the stereo to the yellow on the female iso and then connect the yellow from the stereo to the red on the female iso
Offline golf-sib
  • Турботазик
« Reply #6 on: 23 January 2010, 18:12 »
So a swap round, whats the best way, cut strip and twist? or can u unlodge the pins?
1.8T AGU..
R135
  24
« Reply #7 on: 23 January 2010, 18:15 »
cut strip and CRIMP
don't attempt to remove the pins from the block unless you have the correct tool as you will ruin your plug otherwise
Offline golf-sib
  • Турботазик
« Reply #8 on: 24 January 2010, 22:49 »
Thanks troublestarter I did the switch between the colours and it still kept reseting, so I merged both the colours and made them run parellel to the yellow 12v, work like a charm, thanks for all the help everyone!
1.8T AGU..
R135
  24
