Author Topic: Dim-dip??  (Read 3037 times)
Offline whiter_than_white
  • Seize the day or die regretting the time you lost!
Dim-dip??
« on: 21 January 2010, 22:43 »
tonight called at my local shop to get some cash, pulled up in front of the window so thought I'd use it as an opportunity to check my front lights, what I noticed that I haven't noticed before is that when sidelights are on the dip beam is also on but only dimly lit? Is this normal? I have never known of a vw to do this before?? I know older fords use to,
have I got a fault somewhere??
Car is a '96 P 8v GTi
« Last Edit: 21 January 2010, 22:47 by whiter_than_white »
Offline Matty-MK3
  • Automatic boats FTW.
Re: Dim-dip??
« Reply #1 on: 21 January 2010, 22:52 »
Normal on GTIs/VRs and GLs.
Possibly SEs too.
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
Offline Cable
Re: Dim-dip??
« Reply #2 on: 21 January 2010, 22:53 »
I think theres a relay or summin u can take out to stop that.
Not 100% though
Offline GuessWho
Re: Dim-dip??
« Reply #3 on: 21 January 2010, 22:57 »
Hack off the yellow resistor, with HIDs it's as annoying as f**k.
Offline Matty-MK3
Re: Dim-dip??
« Reply #4 on: 21 January 2010, 23:16 »
with HIDs
 :lipsrsealed:
There is indeed a yellow resistor near the drivers wing.
« Last Edit: 21 January 2010, 23:32 by Matty-MK3 »
Offline roger1234
Re: Dim-dip??
« Reply #5 on: 21 January 2010, 23:30 »
You could have a bad earth on your sidelights causing it to earth through your headlights.
Offline Matty-MK3
Re: Dim-dip??
« Reply #6 on: 21 January 2010, 23:32 »
It might make more sense to be VWs Dip-Dim resistor working 100% correctly.
Offline roger1234
Re: Dim-dip??
« Reply #7 on: 21 January 2010, 23:35 »
What's a dip-dim resistor?
Offline Matty-MK3
Re: Dim-dip??
« Reply #8 on: 21 January 2010, 23:36 »
Makes dipped beam come on dimly with sidelights, called Dayglo.
Offline roger1234
Re: Dim-dip??
« Reply #9 on: 21 January 2010, 23:39 »
Mine don't do that.
