Author Topic: 288mm calipers  (Read 4340 times)
Offline Cable
288mm calipers
« on: 20 January 2010, 21:37 »
i have got 280mm brakes at the moment, does anyone know if the 288mm calipers and carriers will bolt straight onto my hubs?   thanks Zack
Offline Ess_Three
Re: 288mm calipers
« Reply #1 on: 20 January 2010, 22:07 »
I think they will.
I'm sure all Mk3 5 bolt hubs were the same...so as long as you have the calliper, carrier, discs and the correct brake hoses (they are different) then it'll all bolt on.
..but gaining motorcycles.
Re: 288mm calipers
« Reply #2 on: 20 January 2010, 22:43 »
Mk3's are 288 anyway or am I wrong, if not you cannot get much gain with 8mm bigger disc.
Offline boneybradley
  • Back in a Mk3...
Re: 288mm calipers
« Reply #3 on: 20 January 2010, 22:51 »
upto mid 95 they were 280mm...but you'll have abs issues (and I'm sure the hubs are different as the 288 discs are offset differently)
Offline AudiA8Quattro
Re: 288mm calipers
« Reply #4 on: 20 January 2010, 23:09 »
Should be fine. According to ETKA early and late models have exactly the same hub.
Offline Khare
  • The bear that khares
Re: 288mm calipers
« Reply #5 on: 20 January 2010, 23:11 »
As boney said, but as you say only 8mm gain...Unless the stuff is free then I wouldn't spend money upgrading, I'd just chuck a good set of pads and discs on there.
Re: 288mm calipers
« Reply #6 on: 20 January 2010, 23:12 »
True. But if all the bits are available on the cheap, its worth upgrading.
Otherwise put a good set of pads on.
Either way there won't be any ABS problems.
Re: 288mm calipers
« Reply #7 on: 20 January 2010, 23:13 »
I can see the point in going from say 256 to 280 but 8mm is nothing and I dont think you will notice any difference unless it is cheap / free.
Offline Khare
Re: 288mm calipers
« Reply #8 on: 20 January 2010, 23:15 »
My exact views. Save the pennies and buy decent pads and discs, unless you are getting all the kit for free or for stupid money.
Re: 288mm calipers
« Reply #9 on: 20 January 2010, 23:17 »
I thought that's what i said  :rolleyes: :tongue:
