Author Topic: 288mm calipers  (Read 4326 times)
Offline Khare
  • The bear that khares
Re: 288mm calipers
« Reply #10 on: 20 January 2010, 23:18 »
I thought that's what i said  :rolleyes: :tongue:
yes yes it is  :cry: Although I said discs too  :tongue:
Offline AudiA8Quattro
Re: 288mm calipers
« Reply #11 on: 20 January 2010, 23:26 »
Yes you did.
I've never been a fan of performance discs or pads, as they always seem to wear far too quickly.
A proper OE setup, which is actually working as it should is normally very good.
Offline Ess_Three
Re: 288mm calipers
« Reply #12 on: 20 January 2010, 23:39 »
I can see the point in going from say 256 to 280 but 8mm is nothing and I dont think you will notice any difference unless it is cheap / free.
8mm larger is nothing...
But they are 5mm thicker (I seem to recall...25mm vs 20mm) and hence have a much higher thermal capacity...so they won't overheat and fade as fast.
Make sure the 288mm set up you get is the Mk3 288 set up, not the A3/Mk4 set up...as the offset is different.
They both fit, the Mk3 stuff goes straight on, whilst the Mk4/A3 stuff needs a 6mm spacer behind the calliper carrier to space them inwards to line up with the later offset disc....which means you also need 6mm longer high tensile longer bolts to bolt the carriers to the hubs.
If you are going later style 288s, just go the whole hog and fit 312s - if your wheels will cover them.
..but gaining motorcycles.
Re: 288mm calipers
« Reply #13 on: 20 January 2010, 23:40 »
I stand corrected, thanks for the info.
Offline GuessWho
Re: 288mm calipers
« Reply #14 on: 20 January 2010, 23:54 »
Both 280 and 288 use the same hubs and I'm fairly sure calipers IIRC.
Offline Cable
Re: 288mm calipers
« Reply #15 on: 20 January 2010, 23:57 »
Thanks, well i have the calipers and carriers, i guess all i need is the flexi hoses? upgrading because they are slightly thicker and i am putting a vr in. Only have 15" wheels, im going to get 16" soon but not sure when.
Offline GuessWho
Re: 288mm calipers
« Reply #16 on: 21 January 2010, 00:02 »
If you are going 16" then there is a good chance 312mm will fit, there's a couple of set up's on E38 for £150 ATM you could sell your parts and get those if you wanna scare people behind you. :lol:
Offline Cable
Re: 288mm calipers
« Reply #17 on: 21 January 2010, 00:06 »
yh 312mm will fit the 16" but just not 100% on what wheels ii like atm. ill take a look thanks
Offline GuessWho
Re: 288mm calipers
« Reply #18 on: 21 January 2010, 00:07 »
No probs, can't link you ( :grin:) but they're in the classifies somewhere. I was thinking of it but too much work for a sh!tty 1.4
Offline Ess_Three
Re: 288mm calipers
« Reply #19 on: 21 January 2010, 09:41 »
They will fit any OEM type 16" single piece wheel...but milti-piece prove a problem.
BBS RXIIs won't fit without slight calliper clearancing - about 4-5mm off the high spots.
Then, they'll fit with RXIIS also...tight, but they'll fit.
I know this because I have them on mine!
