I was running coilovers and it was rubbing the rear shock, ok
Also any reason why you seem to pick on everything I post.
I don't pick on everything you post...only the plainly incorrect stuff.
Anniversary GTIs come with 7" wide wheels, ET43 and I have both those, and coilovers...and have no rubbing.
So you can't say it will rub.
I never had rubbing standard...neither did VW, which is whay they chose to type approve 7" wide ET43 wheels for the Mk3.
Maybe it's the brand of coilover...which you chose not to mention in your previous post?
Giving the impression 7" wide ET43 wheels will rub on a standard Mk3 Anniversary (which the OP has) is incorrect...unless SEAT have different lengths for 7" and 43mm to VW?
