Author Topic: Shady's not got a problem with his GL! (thanks for the advice)  (Read 6650 times)
Offline Shady Pioneer
  • graphic designer.
Re: URGENT!! Shady's got a problem with his GL!
« Reply #40 on: 16 January 2010, 18:53 »
You could get a dizzy + dizzy cap from a scrappy for real cheap. Also try replacing the plug leads, if they look too ugly  :sick:
where can he find a new driver then  :laugh:
Bastard lol!
« Reply #41 on: 16 January 2010, 19:34 »
Maybe it has had enough and called it a day by losing compression.
  • graphic designer.
« Reply #42 on: 16 January 2010, 19:38 »
I hope not, otherwise it's new engine time lol! I'm going to sort out the dizzy tomorow, and if it doesn't work, Adam a has kindly offered to get the AA out for me on his breakdown cover. :)
« Reply #43 on: 16 January 2010, 19:41 »
Sounds like a plan.
Offline JC
  • Back in the North.
« Reply #44 on: 16 January 2010, 21:29 »
Sounds like a plan.
Like wot I said  :lipsrsealed:
Offline Guy
« Reply #45 on: 16 January 2010, 22:01 »
:grin: :grin:
shady have u tried spraying wd40 in the dizzy?
Is it safe to do that? Lol! Should I try and clear any moisture first then spray WD40 in it?
Mikester is right.. WD-40 repels the moisture..
WD-40 stands for Water Displacement and was perfected on the 40th attempt
new dizzy and rotor arm will be pennies from your local GSF/ECP
check all conx with HT leads, battery connection etc
Offline av_golf
« Reply #46 on: 16 January 2010, 23:10 »
coil pack could be burnt out too? best thing to do is let someone have a look or yea do it on a mates aa cover
  • graphic designer.
« Reply #47 on: 16 January 2010, 23:22 »
:grin: :grin:
I never knew that was what WD40 stood for, you learn something new every day. :)
I'm hoping it'll all be sorted tomorrow, if not, looks like it'll be the AA guy telling me what needs to be done/changed, and we will go from there, I hope this things runs until August, then I can scrap it.  :evil:
  • graphic designer.
Re: Shady's not got a problem with his GL! (thanks for the advice)
« Reply #48 on: 17 January 2010, 11:12 »
Thanks to all who put in advice (and sarcasm as usual lol). Car is running again fine now, it was moisture in the dizzy so WD40d it up and all is gravy. :afro:
Offline leegt5
« Reply #49 on: 17 January 2010, 11:19 »
Glad you got it sorted.. Always a relief when its something simple !!
