Author Topic: Indicators havew died!  (Read 833 times)
Offline ramps
« on: 14 January 2010, 08:44 »
Some of you may remember i lost my keys, so heres the rest of he story......
I had to buy a new ignition barrel and obviously to fit it I had to remove the steering wheel, indicator, window wiper and hazard light switch. after re asbleing it all I ended up breaking the hazard light switch, What I want to know is, is the indicator circuit wired through that hazard switch? when i go to turn the indicator on left the dashboard warning light stays constantly illuminated and then when you just have it in a neutral position the warning light is just on but very dull.
Re: Indicators havew died!
« Reply #1 on: 14 January 2010, 10:08 »
yep they are, so replace that and it should all work again :)
Offline ramps
« Reply #2 on: 14 January 2010, 15:09 »
thanks dude, now does anyone if anywhere aftermarket sells them? In my golf the sitch is a' top the steering column. Is it a trip down to vw?
« Reply #3 on: 14 January 2010, 15:30 »
vw wont sell the switch seperate im afraid, so you';ll want the entire stalk:
357 953 513 F  01C - 43.39+VAT
I think you can get aftermarket tho, try givin veew services a bell:
http://www.vwsonline.co.uk/car_parts_bristol/
edit: if you have good scrappies local MK3 stalks have the same hazzard switch, just have to strip it off the stalks then swap the big hazzard button for the mk2 square one
Offline Ben Lessani
« Reply #4 on: 17 January 2010, 11:17 »
My indicators are doing the exact same thing :( I haven't had a chance to properly poke it - but I've got a pre-90 hazard setup.
