Author Topic: Head gasket  (Read 13254 times)
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: Head gasket
« Reply #40 on: 15 January 2010, 20:04 »
ive rebuilt a few engines over the years and can tell you know that if you take your car or cylinder head complete with cams etc. they will be able to send it to an engineer and what they will do is strip it down and then skim the head and then reseat all valves, clean the lifters, put in new valve seals and refit cam etc. this should come to no more than £500. Your cylinder head will come back looking brand new. then with the head kit you will have left over the headgasket and head bolts to fit.
this will do fine, no need to get a new head as that would still want skimming if its second hand.
Offline Purely VAG
Re: Head gasket
« Reply #41 on: 16 January 2010, 04:07 »
Is there actually much proven difference between the large port/small ports?
Ive not seen any... Its not like we see AGU's bhp topping AUM's with same turbo is it?
Jrd,
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline Grand Master Patch
Re: Head gasket
« Reply #42 on: 16 January 2010, 10:32 »
Very good question?
I guess he'd get less mpg due to loosing the vvt(would he need AGU cams) and he may need to tweek the map to suit?
Offline barry-gti
Re: Head gasket
« Reply #43 on: 16 January 2010, 10:35 »
Very good question?
We was actually talking about this yesterday, isn't there a way to put the AUM Cams and Sensors for the VVT into the AGU head or something like that?
Thats good info, Cheers for that mate. And i was only going to get a new head because i've got AUM and AGU Ports are bigger. But it seems like its more hassle than its worth...
Jrd,
from what i've seen from R-Tech Rollers the AGU's with K03s do gain a bit more BHP. BaV Is pretty close to them though...
Offline tonyg
Re: Head gasket
« Reply #44 on: 16 January 2010, 12:33 »
£500 is extremely steep i pay around £200 with a reciept for this at a local machine shop in Warrignton, head comes back like new!
Offline Hulmie
Re: Head gasket
« Reply #45 on: 16 January 2010, 12:45 »
This was on a Calibra cylinder head though. think theres more work involved.
Offline BaV
  • 2001 Golf GTI 1.8T AUM
Re: Head gasket
« Reply #46 on: 16 January 2010, 13:55 »
The only reason AGU's top most AUMs with same turbo is because they are apparently easier to map as they have less sensors and stuff holding them back.
And you can still run an AGU with vvt you just need to swap the tensioner / sensor thingbob from the AUM head which is what im doing.
Offline barry-gti
Re: Head gasket
« Reply #47 on: 16 January 2010, 15:41 »
When AD let me know whats happening do you think i should just stick with my head if it isnt Cracked?
Offline BaV
Re: Head gasket
« Reply #48 on: 16 January 2010, 19:06 »
Well if you can get a AGU head and inlet for cheap enough then i would probably go with that and use the bits from your head to get the vvt to work.  And as for the injectors im sure A D would be able to get them to fit
Offline MaXXeH
  • Golf MK5 GTI
Re: Head gasket
« Reply #49 on: 16 January 2010, 20:08 »
You can use your injectors in the agu head you just need spacers.
i looked into this when i was going to put some TT ones into mine.
