Author Topic: sub to amp wiring help needed  (Read 2268 times)
Offline ian007miles
« on: 13 January 2010, 21:31 »
sorry to be a pain right ive just looked at my amp and now i need i now the best way to connect the sub to the amp heres a link to the instructions for the amp; http://images.kenwood.eu/files/prod/746/5/KAC-PS1D_(EN).pdf the thing id ive looked at it and its all confusing to me (but thats just me)
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline tommk3cab
Re: sub to amp wiring help needed
« Reply #1 on: 14 January 2010, 16:49 »
wire the sub up in parallel as I mentioned in the other post then wire the two wires from the sub into either of the two pairs of +ve and -ve inputs on the amp.
Offline S11EPS
  • No golfs here. Only a C63 mercedes
« Reply #2 on: 14 January 2010, 17:31 »
I think that sub already has bus-bars installed to wire the two voice coils in parallel, as standard
(You need remove them if you're planning on wiring in series or running a separate amp for each VC)
Soooo, All you need to do is connect one pair of wires (pos and neg) to one set of terminals, and robert's your fathers brother.
The greatest leveller of them all - the Carousel
Offline ian007miles
« Reply #3 on: 14 January 2010, 18:43 »
Right I'm a bit confused I'm going to wire the sub in parralel using the bus bar that came with the sub so there will be 1 set of wires 1+ and 1- and the thing that I don't understand is what terminals on the amp should I connect the speaker wires to
Offline tommk3cab
« Reply #4 on: 15 January 2010, 15:37 »
There should be 4 terminals yeah? 2x +ve and 2x -ve. Use any +ve and any -ve on the amp it doesn't matter.
