Author Topic: MOT Failed on seized handbrake cable.  (Read 2951 times)
Offline shakman
« on: 13 January 2010, 14:47 »
As i suspected i failed my MOT on a seized handbrake cable :(
I'm guessing water was getting into it.
The mechanic hasn't given me a price on the repair yet. But i just wondered how much does it normally cost to supply and fit a new cable?
Thanks.
Offline Reasty
  • Alpine white valver.
Re: MOT Failed on seized handbrake cable.
« Reply #1 on: 13 January 2010, 14:54 »
I'd get the cable yourself from gsf or eurocarparts,to make sure they don't try rip you off,a cable won't be alot and then maybe an hours labour so your looking at under 100 quid I'd say.
Offline shakman
« Reply #2 on: 13 January 2010, 14:58 »
Ah that's ok. Cheers for the quick reply!
The mechanic is a kind of friend, and normally gives me a discount so hopefully won't rip me off. I think he has the part ordered, so i'll see what happens.
Offline dan_apps
  • too low for british roads!
« Reply #3 on: 13 January 2010, 15:02 »
are u handy with a spanner? if you take a look on Ben Lessani's project thread he does have a step by step guide on there about fitting one! :smiley:
Offline Jay
  • balding fat cvnt
« Reply #4 on: 13 January 2010, 15:14 »
They're easy to replace so an experienced mechanic shouldn't take more than 30 minutes to replace it and get it adjusted properly.
Offline theclash
« Reply #5 on: 13 January 2010, 19:11 »
mate just had his done 10 quid for the cable 30 quid fitting at a garage.
Offline Sam
  • Sam I am
« Reply #6 on: 13 January 2010, 19:31 »
If you had waited a couple of days you would have known that the pass rate for a mk2 is 1/2..... then all would have been alright
Offline theclash
« Reply #7 on: 13 January 2010, 19:45 »
what u mean  :huh:
Offline Jay
  • balding fat cvnt
« Reply #8 on: 13 January 2010, 20:41 »
The statistics have been released for MOT failure rates, MK2's are ~50% either way according to the stat's. Not bad for mostly 20+ year old cars  :cool:
Offline fishnchipsx2
« Reply #9 on: 15 January 2010, 03:31 »
£100 would be a rip-off.  £30-£40 sounds about right to me...  £10 for the cable, then 30mins MAX labour for fitting.  Where a car-lift etc is available, should only take about 10-15 minutes to fit and adjust!
