Author Topic: No power, no revs  (Read 10981 times)
Offline Jay
  • balding fat cvnt
Re: No power, no revs
« Reply #10 on: 13 January 2010, 16:55 »
you did put diesel in it yes ?
Yes  :tongue:
It sounds like someone has put petrol in it.
Does it smoke at all?
Only put Diesel in it and only normal steam/condensation when first starting it up.
Recovery come out and turned the car on, pressed the accelerator it did the same and then came...
 :lipsrsealed:
Bloke: "Sir, it does look like the throttle isn't talking to the ECU."
Me: "Can we try cleaning it to see if that sorts it?"
Bloke "No"
Me "OK, can you tow me in that ickle van?"
Bloke "No"
Me "So how we going to get me home/to a garage?"
Bloke "I'll get a recovery truck to pick you up, should be here in an hour but could be longer because of all the call outs."
Me "Good thing I wasn't on the side of the road then Like I was this morning when I first called recovery"
Bloke "You called this morning?"  :shocked: :shocked: :shocked:
Me "Yes, at about 9:30am - it's now 4:30pm"  :angry:
Offline Rhyso
« Reply #11 on: 13 January 2010, 16:58 »
What a fooking T O S S E R  :angry:
Offline Jay
  • balding fat cvnt
« Reply #12 on: 13 January 2010, 17:09 »
Sounds like my TPS might have got wet  :sad: Hopefully it just needs drying out and resealing to stop water getting back in!
Will keep you guys posted!  :smiley:
well tbf, it was an ickle van smaller than the BUS   :laugh: But still, not even an attempt to fix it  :sad: So much for the Engine  diagnostics and roadside repair on the side of his van  :rolleyes:
Offline JC
  • Back in the North.
« Reply #13 on: 13 January 2010, 20:11 »
i shoudn't
but
 :grin:
Offline Mew
« Reply #14 on: 13 January 2010, 20:42 »
i shoudn't
but
 :grin:
I might join you :lipsrsealed:
You really don't have much luck with cars Jay, although i guess you've already worked that one out!
Offline Jay
  • balding fat cvnt
« Reply #15 on: 13 January 2010, 21:11 »
Worked that one out  :cry: The more I spend on cars initially, the more they cost in the long run! £200 'banger' MK2 as my first car and it lasted the longest with not much attention!  :laugh: I should have just bought 10 £200 bangers  :grin:
Working @ home tomorrow so I can try get it sorted in the morning.
Offline topher
  • Administrator
  • fully functioning
« Reply #16 on: 13 January 2010, 21:36 »
overtaking a bicycle? something fishy there mate.. you sure you didn't go back to pick a fight with that stream and lost again? :grin:
Offline Jay
  • balding fat cvnt
« Reply #17 on: 13 January 2010, 21:57 »
Yup, I'm sure. I avoid 1cm deep puddles  :laugh: It was just after a ped crossing and the cyclist was all over the road... he needs cycling lessons  :laugh:
Offline JC
« Reply #18 on: 14 January 2010, 09:03 »
I just LOL'd at work - LOUD one at that ,  just had to explain Jays paddling exploits  :grin:
Offline Jay
  • balding fat cvnt
« Reply #19 on: 14 January 2010, 09:50 »
This car's air intake is like 3 foot up so wouldn't have been a problem in that situation  :smug: :tongue:
It was not wet when I took it out (well a bit of condensation build up but the whole car suffers that) and cleaned off all the dust and muck on the TPS/Peddle sensor, just going down to clean the plug inside the car.
The REALLY annoying thing is when the guy came to recover me it only bloody worked! so I was able to reverse and get on the trailer OK, same as when we got back to mine  :rolleyes:
Putting it all back together in a few mins and will take her for a drive after some in Neutral testing.
