Author Topic: Starting Woes  (Read 1377 times)
Offline BelperJim
Starting Woes
« on: 12 January 2010, 13:56 »
Hi all,
Having problems starting my 16v.
Basically takes about 6 or 7 attempts to get her going.
The fuel pump primes constantly. I have tried replacing the fuel pump relay and have a replacement ECU and Ignition Unit both of which I have tried and still it primes constantly.
This has steadily got worse over the last couple of months.
Any help appreciated!
Re: Starting Woes
« Reply #1 on: 12 January 2010, 15:47 »
sounds liek you have a fault in the wiring loom, the pump relay is triggered by a signal from the ecu, if you look in the scuttle area you'll see a 2 pin plug with a red/yellow wire this is the fuel pump relay trigger from the ecu. its an earth signal, so id guess someone has run this wire to earth for some reason?
what number is on the relay, it should be 67, 80 or 167
Offline BelperJim
Re: Starting Woes
« Reply #2 on: 12 January 2010, 16:17 »
I'm not 100% sure on the number but I know it's Blue. I can check the number when I get out of work. I'm going to hazard a guess at 67 from memory.
Re: Starting Woes
« Reply #3 on: 12 January 2010, 16:38 »
ok thats the right kinda relay then, wont be that!
Offline BelperJim
Re: Starting Woes
« Reply #4 on: 12 January 2010, 16:46 »
I bought a new relay to test the problem so I have kinda already ruled that one out.
I have a multimeter and time to spare and I really want to get the old girl back to her best.
What should I be looking for at the relay trigger?
Offline mattkh
Re: Starting Woes
« Reply #5 on: 12 January 2010, 17:22 »
Hi all,Having problems starting my 16v.Any help appreciated!
Hi
What engine code is it ?
Offline BelperJim
Re: Starting Woes
« Reply #6 on: 12 January 2010, 17:29 »
It's a standard 1991 16v. So I presume it's a KR without going out to look at the block.
Re: Starting Woes
« Reply #7 on: 12 January 2010, 17:44 »
lookin for anything dodgy looking wiring wise! if you disconnect the 2 pin plug the fuel pump shouldn't prime or run at all once ign switched on again, if it does the wiring is fudged between there and the fusebox.
if you earth the red/yel wire with the ignition on the pump should run, obv need to earth the fusebox side of the plug rather than ign controller side.
Offline BelperJim
Re: Starting Woes
« Reply #8 on: 12 January 2010, 17:51 »
Okay Jonny I'll test it tonight and see how it goes.
Thanks for your help so far!
Offline BelperJim
Re: Starting Woes
« Reply #9 on: 12 January 2010, 18:35 »
Is the two pin connector I'm after the one attached to the ecu? If so the pump still primes with this detached.
