Author Topic: Starting Woes  (Read 1378 times)
Re: Starting Woes
« Reply #10 on: 13 January 2010, 11:26 »
its in the scuttle area close to the ecu, 1 end of it goes to the ecu plug, the other runs to the fusebox.  if pump still runs with this disconnected then you've deffo had a bit of wire bodgery there! I'd take the main scuttle trim off and follow the loom as best you can, hopefully the problem will become obvious. look all over the engine loom for insulation tape, usually a clue that something has been repaired.  I say repaired, but I've yet to remove a bit of tape to find a nicely done fit, its usually covering something horrible  :grin:
Offline BelperJim
Re: Starting Woes
« Reply #11 on: 13 January 2010, 11:36 »
Okay that was the right plug. It definitely primes without it connected.
I will follow the wire and see what I can find. The back of the fusebox is a nightmare  :sick:. Car is now on it's second aftermarket Cat 1 alarm so has had muchos fiddling.
Thanks for the help. I'll let you know how it goes!
