Author Topic: Oil coming out dipstik  (Read 1358 times)
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Oil coming out dipstik
« Reply #10 on: 07 January 2010, 11:04 »
I was about to say the breather had frozen up. But if your water temp also went sky high, then make sure your coolant has not frozen up too. Either that or you have a damaged piston causing crankcase compression.
Offline jezza16v
« Reply #11 on: 07 January 2010, 12:07 »
Have to agree, sounds like the coolant was frozen as well, get some more antifreeze in there or you'll strip the blades off the waterpump impeller or worse!
Offline beechymonza
  • mad beech
« Reply #12 on: 07 January 2010, 12:42 »
Yeah i was wonderin why it affected my coolant temp, Just been out 4 about an hour drivin, An its all ok now, So gunna lamp some more anti freeze in, just 2 be on safe side,
cheers lads, :cool:
No guts No glory,
