Author Topic: Oil coming out dipstik  (Read 1360 times)
Offline beechymonza
  • mad beech
« on: 07 January 2010, 09:27 »
Went out this mornin -8, Anyway as i was drivin after about 10mins noticed temp gauge close 2 maximum, Got home an lifted bonnet, An oil splattered everywhere but water level fine, Put sum oilin an started it up, An it was startin to puff out dipstik,
I rang my mate an he reckons breather blocked ,GTI 16v
No guts No glory,
VeeDubGTI16v
Re: Oil coming out dipstik
« Reply #1 on: 07 January 2010, 09:35 »
yep breather sounds like the culprit!
Offline beechymonza
  • mad beech
« Reply #2 on: 07 January 2010, 09:37 »
Its cold out there, Where abouts is it situated so i can head straight for it, An what should i do with it, :cry:
No guts No glory,
VeeDubGTI16v
« Reply #3 on: 07 January 2010, 09:54 »
on the front of the block its the ally bit with a large diameter pipe coming out and going to the airbox via the inlet. if you take the housing off the block i believe theres a gauze in there that could be blocked?
Offline beechymonza
  • mad beech
« Reply #4 on: 07 January 2010, 10:00 »
yeah i can see it, I not gunna start tekin that off in this weather though, Well not on my front lawn i ay  :cry: :grin:
No guts No glory,
VeeDubGTI16v
« Reply #5 on: 07 January 2010, 10:02 »
don't blame you lol, the allen bolts aren't the easiest to get to
Offline beechymonza
  • mad beech
« Reply #6 on: 07 January 2010, 10:04 »
I just started it up again, An leavin it runnin, So far so gud, It dont help my dipstik is split so its quite easy 2 force out of,
No guts No glory,
VeeDubGTI16v
« Reply #7 on: 07 January 2010, 10:06 »
it might be worth cleaning the pipe out, thats a quick job and might help things a bit.
Offline beechymonza
  • mad beech
« Reply #8 on: 07 January 2010, 10:10 »
Yeah i will do that i think, I been squeezin it, An twice i catched my little finger on alternator belt, You think you would learn the 1st time,especially in this cold weather, :laugh:
No guts No glory,
Offline beechymonza
  • mad beech
« Reply #9 on: 07 January 2010, 10:22 »
Oh well it has fixed itself, Must of been froze or somethin cause i ay used it in 3 days an its been down 2 minus 13 over nite,
No guts No glory,
