Author Topic: Coolant Level  (Read 4840 times)
Offline No Golf Clubs at all
Coolant Level
« on: 06 January 2010, 10:31 »
Hi all,
Jumped (well slid) into my car this morning, started her up and got a BONG! dont drive, coolant level low warning lamp on.
Simply topped up to about 75% of the two marks with some W12? coolant that I had Luckily.
Is it normal to lose some coolant/ fluid? should i be concerned about a leak somewhere?
Let the fun begin........Red Gti, full colour coding, DSG, Xenons, Winter pack, Lux pack, Highline, Sat Nav, Sunroof, Leather, Milltek, ABT rear valance, Goodyear F1 Asymmetrics....pescaras :-)
Offline ub7rm
Re: Coolant Level
« Reply #1 on: 06 January 2010, 11:25 »
Mine hasn't budged a mm since I got it.  I think AlanD had some issues due to a minor leak somewhere and others have asked the same sort of question so I would say if its dropping regularly then yes there is an issue, its not just normal losses.
2020 BMW 128ti
2017 Golf GTD Estate
Offline jaydubveedub
Re: Coolant Level
« Reply #2 on: 06 January 2010, 12:11 »
^ what he said.
Same here, mine hasn''t moved since I've had the car.
The cooling system is essentially sealed so shouldn't lose fluid. It is quite common for the system to 'find it's level' below the max mark on the expansion tank but if it consistently going down below the minimum then you have an issue.
Get it looked at asap.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
Offline ade1703
Re: Coolant Level
« Reply #3 on: 06 January 2010, 15:14 »
I suffered with this on my first GTI, it turned out to be a leaking Flange.
There was a whole discussion when AlanD had the same problem, http://www.golfgtiforum.co.uk/index.php?topic=93475.20
Offline Steve30
  • Ed30 .
Re: Coolant Level
« Reply #4 on: 06 January 2010, 17:56 »
I thought it was Alan's Mrs that had this issue? hahaha :laugh:
Tiguan quicker than the Golf
Offline FamilyDub
Re: Coolant Level
« Reply #5 on: 06 January 2010, 18:06 »
 :laugh: :lipsrsealed:
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline Gene Hunt.
Re: Coolant Level
« Reply #6 on: 06 January 2010, 20:53 »
^ what he said.
..........x 3.
Candy White ED35.
Re: Coolant Level
« Reply #7 on: 07 January 2010, 04:03 »
Thanks all for the information and the inuendo :-)
I'll keep my eye on it over the next few weeks, off skiing on saturday to the alps so I'll note the level and see if any movement on my return.
Meanwhile I'll see if I can get myself some "Flange" in France :-p
Offline Stub70
Re: Coolant Level
« Reply #8 on: 07 January 2010, 16:27 »
Mine did the same this morning. I thought it may be due tot he cold weather?
Offline NewbieGTi
Re: Coolant Level
« Reply #9 on: 07 January 2010, 17:19 »
Had a similar thing with my old Audi A3 (57 plate 1.9TDI). Took it to the dealer expecting a leak and it was a faulty "EGR Cooler", luckily was under warranty at the time.
MK5 (06) GTI; Previous: (57) Audi A3 2.0 TDI & (05) Seat Leon Cupra R 225 & (51) Seat Ibiza Cupra 1.8 20VT
