Author Topic: Coolant Level  (Read 4841 times)
Offline Schuey
Re: Coolant Level
« Reply #10 on: 08 January 2010, 23:20 »
Hi all,
Jumped (well slid) into my car this morning, started her up and got a BONG! dont drive, coolant level low warning lamp on.
Simply topped up to about 75% of the two marks with some W12? coolant that I had Luckily.
Is it normal to lose some coolant/ fluid? should i be concerned about a leak somewhere?
Mine did the same this morning. I thought it may be due tot he cold weather?
Sounds like a faulty coolant sensor, sometimes the cold causes all sorts of problems, mine did the same too!
Offline AlanD
  • MK5 2.0T 16v
Re: Coolant Level
« Reply #11 on: 10 January 2010, 22:15 »
As others have said, I had a leaking flange. This thread might come of use for part numbers etc - http://www.golfgtiforum.co.uk/index.php?topic=100997.0
