Author Topic: insurance question  (Read 2617 times)
Offline john_666
insurance question
« on: 05 January 2010, 23:08 »
hopefully someone can answer my Q... i have a dr10 on my licence it was 5 years ago in december.. i no insurance companies only ask for the last 5 year but do i need to tell them about this as its a serious offence?? i no its on my licence 11 year but just curious to wether i need to tell them
john
Offline Dewey
  • Mk4 1.8t 150 AGU (R-Tech Stage 1 190)
Re: insurance question
« Reply #1 on: 06 January 2010, 18:22 »
you dont have to tell them due it being after 5 years, im led to believe the only reason its on your license for 11 years is so that if you get caught again its easier to tell if its a repeat offence but i cant confirm
So Far - R-tech Stage 1 Re-Map 190hp 225ftlbs, Forge 007P DV, Forge Silicone TIP, Pipercross Panel Filter,  Powdercoated Anthracite Montreal IIs, Custom Cat Back.  Shopping List - Coilovers, Hubcentric Spacers, Front and Rear ARB, Big Brake Set-Up...
Offline john_666
« Reply #2 on: 07 January 2010, 11:58 »
can any one confirm this 100% as i dont want to renew insurance for it to be void
thanks john
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #3 on: 07 January 2010, 13:26 »
Any DR offence over 5 years old should not attract any terms from an insurer, If they don;t ask for anything over 5 years old, there is no need to declare it.  :smiley:
Keeping schtum. Mostly.
Offline DannyOOOOO
« Reply #4 on: 14 January 2010, 16:17 »
you should really declare this type of conviction for up to 11 years.
It is true that it shouldn't change the price once it's over 5 years, but some companies will ask for history for longer.
An example as to why they might do this is be because if you only had one DR10 or something similar it's not a problem but if you were a serial offender with numerous convictions then you might be seen as too high risk for that underwriter and they wouldn't cover you.
So yes 100% declare it coz chances are it won't affect it at all but if they need to know about it, it won't come back and bite you in the ass at a later date  :smiley:
hope this helps
Danny O
HIC
