Author Topic: Clocks dont work.........  (Read 2906 times)
Offline LazyLunatic
  • MK3 20VT Project
« on: 05 January 2010, 13:54 »
Ok i got my clocks plugged in and they light up, also the indicator tell tales work and the main beam light works, also the warning lights work (handbrake, charge, oil, coolant)
Now the two displays, mileage and time, dont work nor do the four dials.
everything else works fine. although also to note, the oil and coolant lights stay on permanently, even when the engine is on.
speedo wiring is plugged into the gearbox and tacho is wired to ecu; so it makes me think thats its some sort of bad earth is missing connection......
i got a pdf with a wiring diagram, its quite good but i cant really see the problem. any help would be much appreciated! i can email the diagram if need be.
thanks! :)
Re: Clocks dont work.........
« Reply #1 on: 05 January 2010, 15:50 »
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2 on: 05 January 2010, 16:27 »
here you go:
http://vwtech.no-ip.info/downloads/g3dash.pdf
yeah i got that and i looked over the earths but cant see what i have missed. i've only messed with the engine bay wiring and i cant see how the clocks earth through the engine bay wiring. mayb im not understanding the diagrams correct.
« Reply #3 on: 05 January 2010, 17:07 »
sounds liek the main live has gone, have you checked the dash fuse?
Offline LazyLunatic
  • MK3 20VT Project
« Reply #4 on: 05 January 2010, 20:33 »
yeah checked fuses and fusebox wiring and nothing has gone or not connected. worked fine before i took my engine and then ever since it been like i described in the first post... will double check fuses again, but i have looked over them a lot.
i thought it might be something to with the oil pressure switch, as it aint wired in yet (at least i dont think it has??)
« Reply #5 on: 11 January 2010, 08:44 »
that wont make a difference if connected or not, these operate just like an on/off switch anyway
Offline LazyLunatic
  • MK3 20VT Project
« Reply #6 on: 11 January 2010, 15:10 »
ahhh, then im out of ideas..... is there anything in the engine bay wiring that might have affected it you reckon? would it be worth trying a set of gti clocks out, as mine doesnt have a mfa?
thanks for your help :afro:
« Reply #7 on: 11 January 2010, 15:19 »
buggered if i can think of anything!  worth checkign all the jumper blocks above the fusebox, one o those may have popped out?  if you look up under the dash you'll see a load of 4 pin jumpery things with single wires going into them, im thinking maybe you've pulled a wire out here...
Offline LazyLunatic
  • MK3 20VT Project
« Reply #8 on: 14 January 2010, 09:24 »
nothing wrong there..... i wonder if i have wired the right wire to the ecu for the tacho....
...i wired in a green and blue wire. could it be another wire maybe?
Offline LazyLunatic
  • MK3 20VT Project
« Reply #9 on: 18 January 2010, 20:26 »
Quote
Use the wiring diagram and a multimeter and check every wire at the dash goes where it says it should. Work methodically from left to right on the diagram starting at T28/3 which should go to Terminal 31, (Chassis ground) and ending at T28/2 which should go to your coolant shortage switch.
Quote
^ guy on my local forum ^
going to give this a go. i guess all the spare wiring in the bay must be the problem/solution!
