Author Topic: Removing Airbox and Fitting Cold Air Kit  (Read 5408 times)
Offline zdebx
« on: 01 January 2010, 17:00 »
I'm not sure if I can do this myself or should take it to a garage, so decided to ask some advice.
Can I simply remove the airbox and connect the induction kit to the "flexi" pipe? The thing I am bit confused about is the 2 pipes that are connected to the air box?
One is the top one, where I have to connect the kit, but what's the bottom one and what is it connected to? I have to remove it too?
I got a 1.8 SE, if that helps
This is the same engine as mine:
And this is the kit I have:
Happy new year  :smiley:
« Last Edit: 01 January 2010, 17:07 by zdebx »
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
Offline roger1234
Re: Removing Airbox and Fitting Cold Air Kit
« Reply #1 on: 01 January 2010, 18:07 »
The other pipe is for hot air on cold mornings. Your car will run a bit s**t till it gets warmed up if you fit a k&n
« Reply #2 on: 01 January 2010, 18:56 »
Worth adding that you can lose power fitting a cone filter due to heat soak issues.
Offline shepgti
« Reply #3 on: 01 January 2010, 19:13 »
sell the cone and buy a panel  :wink:
Offline zdebx
« Reply #4 on: 01 January 2010, 21:47 »
I thought that cone filters are actually good? Makes a nice sound, gets cold air to the engine and looks good too.
So what's the problem?
Offline rocketron
« Reply #5 on: 01 January 2010, 21:56 »
not a prob as such deb. there is a thread doin some rolling road tests on induction kits and modded air box with different panel filters and the result was the modded air box and geuine vag panel filter gave best performance results and sound good too.  :cool:
96 golf GTI 16V
96 T4 1.9TDI
Its a dub thing.
Offline jeessnoid
  • Slow for show
« Reply #6 on: 01 January 2010, 23:14 »
i have the same engine and is easy to install it.
First remove the air box and then fit the cone filter to the pipe , but if it do not fit take out the pipe and fit the cone filter on the otherside of the pipe because that side is bigger than the other one. Then you will need something to keep straight the cone filter and pipe.
Offline zdebx
« Reply #7 on: 01 January 2010, 23:28 »
What do I do with the bottom pipe then? It's connected both to the air box and something else...Can't figure out what, lol
And wouldn't it better and safer to get a stainless fitting kit, like this >>> http://cgi.ebay.co.uk/VW-GOLF-MK3-INDUCTION-FITTING-KIT_W0QQitemZ270441495916QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3ef791bd6c
« Reply #8 on: 01 January 2010, 23:56 »
Not going to make much difference to be honest as it will still soak up hot air inside the engine bay.
Offline zdebx
« Reply #9 on: 02 January 2010, 00:01 »
Then why so many people go for cone air filters, if the hot air is such a problem?
