Author Topic: Removing Airbox and Fitting Cold Air Kit  (Read 5409 times)
Re: Removing Airbox and Fitting Cold Air Kit
« Reply #10 on: 02 January 2010, 00:05 »
Then why so many people go for cone air filters, if the hot air is such a problem?
People tend to fit them for the noise but it has been shown many times on rolling roads that they can cost you bhp.
Offline jeessnoid
  • Slow for show
« Reply #11 on: 02 January 2010, 00:16 »
i have the same engine and is easy to install it.
First remove the air box and then fit the cone filter to the pipe , but if it do not fit take out the pipe and fit the cone filter on the otherside of the pipe because that side is bigger than the other one. Then you will need something to keep straight the cone filter and pipe.
What do I do with the bottom pipe then? It's connected both to the air box and something else...Can't figure out what, lol
And wouldn't it better and safer to get a stainless fitting kit, like this >>> http://cgi.ebay.co.uk/VW-GOLF-MK3-INDUCTION-FITTING-KIT_W0QQitemZ270441495916QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3ef791bd6c
Yes , you have to buy something to keep straight the pipe and filter  something like this  http://www.youtube.com/watch?v=U-n_VGbaqUQ
You just have to get out the air box and then fit the cone filter, but if doesnt fit well change the side of the pipe. (disconect completely the pipe and conect it again in the other side and then fit the cone filter. )
Offline jeessnoid
  • Slow for show
« Reply #12 on: 02 January 2010, 00:20 »
and the bottom is conected to the airbox too , just disconect it dont worry about it its original for the hot air
Offline roger1234
« Reply #13 on: 02 January 2010, 00:21 »
That is a hot topic of debate as many people myself included believe that when the car is moving there is always a fresh supply of cool air that far farward in the engine bay.
« Last Edit: 02 January 2010, 00:28 by roger1234 »
Offline hyland770
  • Vw Golf 1.6 estimated to have around 500+ bhp
« Reply #14 on: 02 January 2010, 01:33 »
i had a cone filter like that fitted to mine and about a month later i took it off and put on the original airbox with a cold air feed going into it and its sooooooooooo much better & cheaper plus with a cone filter fuel economy goes out the window!!
Offline shepgti
« Reply #15 on: 02 January 2010, 01:45 »
the main reason is most people (esp those that drive a mk3) dont have alot of money hence driving a mk3 and therefore simply buy a cone filter for the sound when what is really needed is an enclosed induction system like a bmc cda.
Offline hyland770
« Reply #16 on: 02 January 2010, 10:57 »
have to say, you hit the nail on the head there!
« Reply #17 on: 02 January 2010, 10:59 »
Not going to make a lot of difference as you will still get heat soak.
Offline roger1234
« Reply #18 on: 02 January 2010, 12:48 »
You get heatsoak on a dyno cause the car aint moving and the heat builds up but out on the open road you have a fresh supply of cool air coming into the engine bay all the time.
Offline shepgti
« Reply #19 on: 02 January 2010, 13:30 »
why d'ya think they have a massive fan in front of the car when they dyno.... :smug:
