Author Topic: Forge TIP question  (Read 5104 times)
Offline leeroy86
Forge TIP question
« on: 30 December 2009, 10:40 »
Hi everyone, I have a 1.8 20V t (AGU) and upgrading to a k03s on saturday. My question is will the forge TIP part number FM180IND fit my AGU with a k03s? im pretty sure it will but want to be 100% first  :wink:
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: Forge TIP question
« Reply #1 on: 30 December 2009, 10:49 »
Yes it will mate, just had my k03s fitted using my AGU forge TIP
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #2 on: 30 December 2009, 12:10 »
Yes, I also used the AGU TIP.  Nice snug fit.  (Plus, you don't have to plug the extra hole that'd you have by using the AUM TIP).  ;)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 30 December 2009, 12:16 »
FM180IND is the AUQ one isn't it? You're better off with the AGU specific one but if you've already picked one up cheap you can make them fit. (Front vac lug needs blocking and pcv breather hose may need extending as the DV/accumulator switch places)
« Reply #4 on: 30 December 2009, 12:25 »
No, that's the FMGOLFIND for the AUM/Q etc.  ;)
It is strange how they swap the DV location.  I couldn't get my engine cover on properly with the AUM/Q TIP.
Offline leeroy86
« Reply #5 on: 30 December 2009, 12:28 »
cheers for the reply people. cant wait now for saturday  :grin:
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 30 December 2009, 12:28 »
so they put a 180 in the part number just to confuse things :grin:
Right, something else for me to moan at them about at ordering time :laugh:
Offline Rhyso
« Reply #7 on: 30 December 2009, 12:30 »
Ask them why, if something is to be a DIRECT replacement,  why do they move things around and you have to blank off ports / plugs or cable tie things  :lipsrsealed: :evil: :laugh: :laugh:
Offline Hulmie
« Reply #8 on: 30 December 2009, 12:59 »
Cos there like Diesel owners, Bloody awkward. :laugh:
Offline leeroy86
« Reply #9 on: 03 January 2010, 09:28 »
Morning all,
Well after a freezing day yesterdsay i finally got my k03s on without much problems. I say not much problems but in actual fact there were some bloody awkwars bits. The big problem we had was the AGU TIP trying to fit around the new turbo. :evil: after much problem solving we had to use a junior axesaw to cut a straight fin line down it, so when we forced it on the turbo it would expand slightly. IT WORKED PERFECTLY. I have read numerous posts about this problem however alot of people said the AGU TIP would fit on a k03s as its only 1mm difference in size. 1MM DIFFERENCE IN SIZE ON METAL IS LIKE 1 MILE  :wink: LOL.
Anyway all is good and how it should be but my forge TIP will be ordered tomorrow  :smiley:
my advice to anybody doing the k03s upgrade to either 1) have a forge TIP or 2) a AUM TIP (for anybody new the AUM is the engine code number on the later model mk4 golf gti turbos)
Finally i have a question for some forum guru's as there are many of you.  :wink:
My engine code is AGU but now of course with a k03s. WHICH FORGE TIP DO I NEED AS THERE ARE 2 CODES AS I PREVIOUSLEY POSTED. WILL THE SPECIFIC AGU FORGE TIP NOW FIT NOW I HAVE A K03S?????????????????????????????????????????????????????????????????
Cheers people
Lee
