Author Topic: Forge TIP question  (Read 5108 times)
Offline Grand Master Patch
Re: Forge TIP question
« Reply #10 on: 03 January 2010, 09:48 »
I suspect when they are talking about it only being 1mm difference,they are talking about the forge tip and not the oem one :wink:
Will you be getting the car mapped to suit the new turbo?
The tip you need to order is FM180IND
« Last Edit: 03 January 2010, 09:49 by Grand Master Patch »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 03 January 2010, 10:22 »
or you could use the THS AGU TIP which definitely fits the K03s (first hand experience)
You'll have trouble refitting the engine cover with the AUM TIP on the AGU due to having to swap the DV and PRV round so you'll either have to leave it off or cut it about
Offline leeroy86
« Reply #12 on: 03 January 2010, 10:38 »
cheers guys.
my car has had a stage 1 map by R-TEC
next on the list is FMIC, milktec and de-cat. Then of corse a stage 2 map.
thanks for info guys.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 03 January 2010, 10:52 »
Here you go mate
http://www.thsperformance.co.uk/product/TIP_for_Golf|Leon|A3|Octavia_Pre_2000_THSSIL-VAGINT-1-Black
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #14 on: 03 January 2010, 12:30 »
Forge AGU TIP is the one you need. :)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 03 January 2010, 12:42 »
that's the one he said wouldn't fit (or am I missing the point)
Offline Rhyso
« Reply #16 on: 03 January 2010, 12:45 »
I think he has re-fitted his original TIP hence the extremely snug fit lol
« Reply #17 on: 03 January 2010, 14:24 »
Yes, you are!  :P  :D
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #18 on: 03 January 2010, 14:29 »
ah ok, I'll go and sit back in the corner  :embarassed:
« Reply #19 on: 03 January 2010, 15:01 »
Yes, you naughty boy!    :D  :laugh:
