Author Topic: 16v kr pinking  (Read 6745 times)
Offline leeroy20vt
  • h reg mk2 gti
Re: 16v kr pinking
« Reply #20 on: 31 December 2009, 12:33 »
rite been to garage this morning the co2s ect were a liitle low so turned them up a tad
compression is 200 psi on 2 bores and around 185 psi on other 2 wierd
also checked ignition timing and is spot on  :shocked:
any more ideas
Offline danny_p
Re: 16v kr pinking
« Reply #21 on: 31 December 2009, 16:14 »
any more ideas
within 15 psi is ok, if its a young engine it'll still be setteling, if its old thats weepage past valve seats and rings
all the VW's have gone bar 1.
Offline leeroy20vt
  • h reg mk2 gti
Re: 16v kr pinking
« Reply #22 on: 31 December 2009, 17:30 »
cheers danny the engine has done 148k i think if it original but it has had head rebuilt ported and polished to fast road use so it says on reciept lol   also rehoned and piston rings i think its done around 600 miles since this has all been done
Offline danny_p
Re: 16v kr pinking
« Reply #23 on: 01 January 2010, 04:52 »
it's no where near setteled then,   compression results are near as dammit optimal
Offline mattkh
Re: 16v kr pinking
« Reply #24 on: 01 January 2010, 07:43 »
Hi
Is it just a rado engine or is it a rado shell ?
VeeDubGTI16v
Re: 16v kr pinking
« Reply #25 on: 01 January 2010, 09:41 »
so after setting up the co and using super unleaded its pinking exactly the same?
sounds like a fuel delivery problem then
though saying that i have found kjet takes a few days to settle after a tweak
oh dear that post just earned me a geek medal  :laugh:
« Last Edit: 01 January 2010, 09:56 by veedubgti16v »
Offline leeroy20vt
  • h reg mk2 gti
Re: 16v kr pinking
« Reply #26 on: 01 January 2010, 17:07 »
Hi
hi m8 it is a raddo lump in a raddo shell lol sorry
lol u geek haha  :laugh:
yes m8 seems the same i have even retarded timing a  little more altho its lackin even more power its still pinking will run it for a few more days like u say may settle down but i dout it
my next option is find some were that can check fuel pressure under load i think ?
Offline mattkh
Re: 16v kr pinking
« Reply #27 on: 01 January 2010, 17:14 »
Hi
Thanks for confirmimg that it is a rado shell.
There is a fuel pump inside the fuel tank and one outside. If the rado is a 1990 one, then it may be time to change one of the pumps at a time.
Offline leeroy20vt
  • h reg mk2 gti
Re: 16v kr pinking
« Reply #28 on: 01 January 2010, 17:19 »
Hi
yes i was thinking this but fuel pressure on tick over is good but dont know under load ?
does any one know if the intank pump is the same as a mk2 8v or would it have to be a 16v
also sorry m8 i didnt see ur request for a picy so here it is
still got the mk2s tho lol
« Last Edit: 01 January 2010, 17:21 by leeroy20vt »
Offline leeroy20vt
  • h reg mk2 gti
Re: 16v kr pinking
« Reply #29 on: 01 January 2010, 17:30 »
does that mean there likly to fall a bit and sort its self out ?
