Author Topic: 16v kr pinking  (Read 6724 times)
Offline leeroy20vt
  • h reg mk2 gti
16v kr pinking
« on: 29 December 2009, 19:45 »
this i not in a mk2  its in a raddo  but as far as im aware its the same just hope u guys dont mind me posting it here
any way engine has ported and polished head and has had new rings and a rehone all timing is correct on cam/cam belt , but when its under full load after 4000 rpm its starts pinking
has had a fuel pressure check and all was good as far as i know also metering head changed for a gooden and dizzy/ecu
had to retard dizzy timing a bit to make a little bit better
any ideas
cheers lee
Offline jezza16v
Re: 16v kr pinking
« Reply #1 on: 29 December 2009, 20:47 »
Have you re-timed the ignition off the correct flywheel marker. 6 deg btdc @ idle iirc? What octane fuel are you using, should be 98 at least? Mixture could be a bit weak? If the head has been skimmed the compression ratio will be a bit higher so needs higher octane/richer mixture /retarded timing, could it be running hot?  :undecided: Pinking is very bad for the valves, suggest you retard the timing until it stops while you sort out the problem.
Offline leeroy20vt
  • h reg mk2 gti
Re: 16v kr pinking
« Reply #2 on: 29 December 2009, 20:52 »
cheers m8 it was set up of the rite mark at 6 deg but pinked really bad so have already retarded timing on dizzy
i have been using normal unleaded will have to fill up on super next time round i was thinking fuel mixture to i found a article that shows u how to sort ur mixture out with a multi metre will have a play
Offline Diamond Hell
  • Opinions я Us
Re: 16v kr pinking
« Reply #3 on: 29 December 2009, 22:44 »
Get some proper management on it instead of that retarded mechanical K-jet rubbish.
Until you have some proper diagnostics on it you're going to be pretty clueless about the cause.
Re: 16v kr pinking
« Reply #4 on: 29 December 2009, 23:53 »
Has the head been skimmed.
Offline leeroy20vt
  • h reg mk2 gti
Re: 16v kr pinking
« Reply #5 on: 30 December 2009, 11:09 »
were can i get it diagnosed any ideas
yes m8 it has
Offline mattkh
Re: 16v kr pinking
« Reply #6 on: 30 December 2009, 11:19 »
this i not in a mk2  its in a raddo  cheers lee
Hi
Please put up a picture of your rado.
VeeDubGTI16v
Re: 16v kr pinking
« Reply #7 on: 30 December 2009, 11:25 »
is it a 1.8 or 2.0 rado? the 2.0 uses ke-jet and 1.8 uses k-jet
what fuel are you using? it needs super!
if its a 1.8 go through the setup procedure first, check the fuel pressure, ignition timing and co
im not sure whats adjustable on the 2.0, i think its all done in the ecu using the lambda
oh and ignore the broken record that is diamond hell
VeeDubGTI16v
Re: 16v kr pinking
« Reply #8 on: 30 December 2009, 11:29 »
oops, ignore the ke-jet bit, just read its a kr  :laugh:
for a quick fix you could just back the timing off
Offline leeroy20vt
  • h reg mk2 gti
Re: 16v kr pinking
« Reply #9 on: 30 December 2009, 11:54 »
timings been checked all spot on have backed th timing off on the dizzy but still does it if i back it off any more i will have no power
fuel pressure has been checked i have put normal unleaded init but i will be filling up with super now
any other suggestions
