Author Topic: Calling Troublestarter.... brain pick re CANBUS  (Read 1539 times)
Offline DanoGTI
« on: 29 December 2009, 14:38 »
Hi Mate,
Looking at the F900bt but is there a need for the CANBUS adapters? I thought it was only if you have a MFSW and highline (I don't have either).....
The only other connection thing is a Fakra adapter I think.
Could you confirm if I'm right or not?
Cheers,
Dan
DA Productions
The fine art of diplomacy is telling somebody to "fcuk off" in such a way that they actually look forward to the journey....
Offline troublestarter
Re: Calling Troublestarter.... brain pick re CANBUS
« Reply #1 on: 29 December 2009, 16:42 »
the mk5/6 golfs need a canbus adapter when you fit an afermarket h/u
as there is no ignition live in the standard fakra plug
http://www.awesomeautomotive.co.uk/catalog/product_info.php?cPath=60_65&products_id=684
the canbus system is a way of carrying several pieces of digital information down one wire and the canbus adapter converts this from digital to electrical
when a canbus adapter is fitted it will give you the following connections
ignition live
handbrake
speed pulse
illumination
reverse
it can be done without it by running a cable from the fuse box or the cigarette lighter but this only gives you the ignition live
and if you are fitting a sat nav then you need the speed pulse(unless its a kenwood),handbrake and reverse connections
you will also need the fakrs to iso aerial adapter the same as this
http://www.awesomeautomotive.co.uk/catalog/product_info.php?cPath=60_66&products_id=685
« Last Edit: 29 December 2009, 16:44 by troublestarter »
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline DanoGTI
« Reply #2 on: 29 December 2009, 17:31 »
Thanks - just what I needed to know!  :wink:
Dan
DA Productions
