Author Topic: Advice: removing front spot lights and replacing with air intakes  (Read 4560 times)
Offline simon44
Hi, please can someone help me with two questions:
- how to remove the front spot lights (set within the front bumper)
- is it possible to replace the spots with air intake style vents?
Many thanks,
Simon
Offline VR6-Joe
Are you referring to the section where the indicator and fog lamps are?
If so, put a flat headed screwdriver between the fog light and the reflector, and carefully prise the reflector out, this will reveal two screws for the fog light, unscrew the two screws and pull the fog light out towards you, then disconnect the wiring. Repeat for the other side.
As for the air intakes, I've only ever seen them a couple of times, they're quite hard to get hold of!
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline MowatGTI
Bored Welsh Lad was selling a HUGE group buy months ago.
Might still have some.
Offline VR6-Joe
No, his ones go at the bottom of the bumper (underneath the indicators)
The OP wants the intakes that replace the fogs
Offline hyland770
  • Vw Golf 1.6 estimated to have around 500+ bhp
nothing a bit of 2x4 and some rusty nails wont cure!
i would proably make my own out of cold air intake tube (they sell it at my local motorfactors, apparently its different from normal tube :huh:!!) and some mesh or something!?
Offline Paul86S2
You can make a half decent cold air intake from the existing fog light unit.
If you take the fog light out, then take the lens and bulb unit off you will then be able to see you can remove most of the internal plastic which will leave you with a decent size squarish hole. Tody it all up, paint it to match your bumper, add mesh if you want to and attach some ducting to the rear.
Then you have a free cold air vent which fits the car and has cost you some time and a bit of paint.
Paul
Perhaps I watched too much Blue Peter when younger.
Paul
You missed out sticky back plastic and a washing up bottle.  :laugh:
Offline Matty-MK3
  • Automatic boats FTW.
Yeah and sell me the fog glass, mine are cracked to fook.
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
kells
about 20 quid at dealer for the glass, but tricky to fit and get to seal..
Offline Matty-MK3
£20?
:shocked:
