Author Topic: Car stalls while driving  (Read 3946 times)
Offline micfis
« on: 22 December 2009, 22:33 »
My golf has recently started a new thing. I will be driving at 30-40mph through town and it stalls while driving. This happens on and off every few min. Especially great when the power steering locks!  It also idles and sometime stalls while idling. Rev counter will idle at 10 then drop off below moving up and down and stall if i dont give it power.  It starts up straight away and drives again only to repeat the process. Both while driving and idling. Please any advice appreciated.
Offline zdebx
Re: Car stalls while driving
« Reply #1 on: 22 December 2009, 23:18 »
Actually I'm sometimes experiencing the same thing, only my one stalls when idling, but it's fine when driving normally.
It doesn't stall every time I stop, but sometimes the revs start to drop, and unless I give it a gas, it's going to stall.
The air filter is clean, recently serviced it, so changed the oil, oil filter and spark plugs.
Would be interested what's the problem too.
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
Offline Deano2711
  • 1992 VR6
« Reply #2 on: 23 December 2009, 08:14 »
Hi Chaps     Had this problem recently myself....changed my air filter, plugs and tested plug leads and coil pack, cleaned dizzy cap and rotor arm but still had problem. Removed and cleaned the throttle body and it's been fine since. Have you guys cleaned your throttle body??     Cheers    Deano
Offline zdebx
« Reply #3 on: 23 December 2009, 19:32 »
Thanks for that. Will try cleaning the throttle body and see if it makes any difference.
Offline VR6-Joe
« Reply #4 on: 23 December 2009, 20:17 »
If cleaning the throttle body doesn't work try getting it plugged into vagcom
When I bought my car it kept stalling EVERY time I stopped, got my mechanic to plug it in and it showed up that the throttle position sensor and idle speed sensor were both screwed (both built into the throttle body). A second hand throttle body was put on and it's been perfect since :)
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline javalin
« Reply #5 on: 23 December 2009, 20:46 »
immobilizer?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline popleyruss
« Reply #6 on: 23 December 2009, 20:50 »
I've got this problem also
Just plain dubbin
Offline bored_Welsh_lad
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
