you mk3 boys have got it easy. Try frozen rear brake calipers in mk2s.
Quote from: A7 UFO on 04 January 2010, 14:42you mk3 boys have got it easy. Try frozen rear brake calipers in mk2s.Ohhh time for a mk4 set?
Quote from: Adam on 04 January 2010, 16:49Quote from: A7 UFO on 04 January 2010, 14:42you mk3 boys have got it easy. Try frozen rear brake calipers in mk2s.Ohhh time for a mk4 set?have done that now its a weekend car but hadn't back when it was used on a daily basis...yes, I know I'm special.
not had real problems with the golf but been borrowing my brothers corsa this wknd + the locks were always frozenanswer: get a lighter+ heat up the metal key, if it doesnt work straight away, put the key half in the lock+ then heat the part left sticking out to transfer heat to the lock barrel, your in within secondsnot quite so helpful for non smokers though
Quote from: axewielder on 04 January 2010, 14:33not had real problems with the golf but been borrowing my brothers corsa this wknd + the locks were always frozenanswer: get a lighter+ heat up the metal key, if it doesnt work straight away, put the key half in the lock+ then heat the part left sticking out to transfer heat to the lock barrel, your in within secondsnot quite so helpful for non smokers thoughGood way to bend your key i'd say doing that?The frozen lock is the easy part for me, the hard part is having to wait 20 minutes for the dead-locks to un-freeze so i can get in the door! Had the door card off today and covered it in WD40, not convinced it will work but a matter off elimination!Also diping your key into water before trying the barrel is surely going to make it worse in the long run as the moisture may linger there and freeze on another day, especially as the weather is staying cold it wont evaporate.
