Author Topic: More RNS510 Q's  (Read 5428 times)
Offline mags
Re: More RNS510 Q's
« Reply #10 on: 20 December 2009, 16:06 »
My local VW dealer are going to have a go at it this week, I am basically not able to use the MFSW, the reverse camera or have any of the info from the head unit displayed in the MFD
MK6 Gti Carbon Grey, DSG, 19in BBS, Bluetooth, RNS510, Luxury Pack, Leather, Cruise control, Tyre indicator, Park assist, Front and rear sensors, Reverse Camera.
Offline Aidy06
Re: More RNS510 Q's
« Reply #11 on: 21 December 2009, 12:49 »
Needs coding with VagCom, i had the same problem when i fitted mine mate. Somebody off the mk5golfgti forum did it for me for free, stealers wanted the car for half a day at £75 + VAT per hour IIRC. It only takes 10mins todo  :shocked:
Offline mags
Re: More RNS510 Q's
« Reply #12 on: 21 December 2009, 18:10 »
Hi Aidy, do you know exactly what needs coding as my local dealer are doing me a favour (it is Xmas!) and I want them to get it right.  Thanks
Offline Aidy06
Re: More RNS510 Q's
« Reply #13 on: 21 December 2009, 19:52 »
TBH mate I'm not to sure, the lad who I had do it had done it before. My dealer didn't have a clue what I was talking about. I'll have a look and see if I can find anything for you pal
Offline Aidy06
Re: More RNS510 Q's
« Reply #14 on: 21 December 2009, 19:58 »
Hmm, I didn't notice any PM other than your first contact. I noticed that you had successfully installed your RNS as well as trying to establish contact with someone with a vag com.
What I did was using latest 908 software on Vag-Com, got into Nav module 37.
and changed the long code to something suitable for my car. 04010400040000A200
you can do it in code -07, where you will find a line with a lot of boxes. Each box represent 2 digits of the long code (9boxes). when you place the mouse pointer over each box, a dialogue box appears giving you various options. like sound system, speaker monitoring, etc. at the end, you need to enable BAP function. I believe this enable the RNS to talk to the MFSW and DIS
the long code I chose in the end correspond to my car configuration., 160 hp, MFSW, non VW sound system(I don't have Dynaudio) etc. when done, press do it and its coded.
I took a photo of each crucial step with my cam/phone so that I could keep track in case I need to backtrack.
Offline Aidy06
Re: More RNS510 Q's
« Reply #15 on: 21 December 2009, 19:59 »
Just found that in my inbox on VWNAVI, maybe it will help
Offline mags
Re: More RNS510 Q's
« Reply #16 on: 22 December 2009, 10:09 »
Thanks, I don't understand any of that but I am sure it will help :laugh:
Offline Aidy06
Re: More RNS510 Q's
« Reply #17 on: 22 December 2009, 10:11 »
Let me know how you get on buddy, if they try charging you tell them to stuck it
Offline cameluk
Re: More RNS510 Q's
« Reply #18 on: 22 December 2009, 11:35 »
I already posted at the top of the first page what needs to be coded  :huh:
Don't take a longcoded string from another car unless it has the same options as yours
