Author Topic: More RNS510 Q's  (Read 5427 times)
Offline mags
More RNS510 Q's
« on: 17 December 2009, 09:05 »
Just fitted my RNS510 which was very easy and took less than 10 minutes thanks to Aidy's step by step guide. My heater controls work but the only function on the MFSW that works is the volume and my reverse camera no longer works which I assume can both be rectified by my local dealer using VAGCOM? The main screen is red and the phone screen is green does anyone know if I can get this can be set so that it is black like my RCD510? also I have the RCD510 available if anyone is looking to buy one  :grin:
MK6 Gti Carbon Grey, DSG, 19in BBS, Bluetooth, RNS510, Luxury Pack, Leather, Cruise control, Tyre indicator, Park assist, Front and rear sensors, Reverse Camera.
Offline cameluk
Re: More RNS510 Q's
« Reply #1 on: 17 December 2009, 17:53 »
VW should be able to recode however their system isn't as flexible as VAGCOM
RVC can be re enabled byte 3 bit 6
You can't change the phone panel, however you can change the overall colour scheme to any of the three posted on this http://vwnavi.com/forums/showthread.php?p=44866 byte 7 bit 4 & 5
Think you also have to enable BAP on the RNS for the MFD byte 7 bit 7
You need to enable byte 7 bit 0 for the MFSW controls
« Last Edit: 17 December 2009, 18:17 by cameluk »
Offline p3asa
Re: More RNS510 Q's
« Reply #2 on: 18 December 2009, 19:42 »
Isn't there 2 versions of the RNS510? One with the rear view camera and one without.
Offline ErikGTI
Re: More RNS510 Q's
« Reply #3 on: 19 December 2009, 09:54 »
As far as I know you have (in Holland) to order it seperately.......so I did  :cool:
I'LL BEAT YOU TO THE BBC STUDIO........
Offline mac7
Re: More RNS510 Q's
« Reply #4 on: 19 December 2009, 11:54 »
There's more than one version of the RCD510 for use with and without camera, DAB. But there's only one RNS510 as far as I know.
Golf R
Offline p3eps
Re: More RNS510 Q's
« Reply #5 on: 19 December 2009, 12:07 »
Thats what I thought too!  I'm keeping my fingers crossed my reverse cam will work with my current RNS510.
The only thing that puzzles me is that if you buy an RCD510 with DAB - the DAB is built into the unit.
If you buy an RNS510 with DAB - does it come as a seperate module?
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline mac7
Re: More RNS510 Q's
« Reply #6 on: 19 December 2009, 12:31 »
The RNS doesn't have a DAB option. Your RNS510 will work with the camera - might just need tweaking with VAG-COM. Some more details here:
http://www.my-gti.com/195/volkswagen-golf-reverse-camera-upgrade-rns510
Golf R
Offline GTD-Smurf
Re: More RNS510 Q's
« Reply #7 on: 19 December 2009, 12:34 »
The RCD510 and the RNS510 can only Have one or the other DAB Module or Camera atatched to it, Not enough skts at rear of unit to atatch both, stupid i Know but thats the way it is unless the latest Versions have now got extra skts ??.
There Maybe a after market Gismo outthere that will make the RNS510 & RCD510 work with both ??? Dunno, maybe someone Does.
Offline p3eps
Re: More RNS510 Q's
« Reply #8 on: 19 December 2009, 13:34 »
I don't have the slightest interest in having a DAB option... but on VW.com you can spec a car with an RNS510 and DAB. You can only have a reverse cam OR DAB though.
Offline p3asa
Re: More RNS510 Q's
« Reply #9 on: 20 December 2009, 12:51 »
You could well be right. I was only going on this aftermarket piece of kit that had different part numbers for RNS510 with and without rear view cameras.
http://www.kufatec.de/shop/product_info.php/info/p1339_iPod-Video-Interface---IMA-Multimedia-Adapter-w-o-OEM-Control.html/XTCsid/b5e3e8819a4684c69ad5dc554abd605e
