Cheer Mr Johnny sir, I have changed the stat and tested the stat in some boiling water before it was fitted and it was all good.
the bottom rad hose stays cold for a good 10 to 15 mins in this weather before it even gets warm so I think the stat is fine.
the car is a Early E reg Digifant, i did see on GSFs site that the do a single wire temp sender, im starting to think its the gauge tat might be a fault, but i cant ba arsed ripping them out.
Might just fit a after market gauge, just want to know what going on on the track when I take it next year.
My main question is, Will the fueling be right if the dash gauge reads low temp, Im sure the ecu sensor is where the ECU is controling the fueling modes from, correct?
