Author Topic: Can't make up my mind: R or GTI? Please help.  (Read 23533 times)
Offline Snoopy
  • Moderator
  • Geoff.
Re: Can't make up my mind: R or GTI? Please help.
« Reply #60 on: 11 December 2009, 22:25 »
Anyone know if the latest generation of haldex still become 2wd under braking?
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline R32UK
« Reply #61 on: 12 December 2009, 07:26 »
Stig never had any trouble with the grip/traction of the haldex, if i remember right they said they were impressed how the R just keeps digging in. :evil: I know its easy to keep comparing top gear track times but its its a course and driver everybody knows and its common knowledge r32 is underpowered and overweight but it beat or got very close to alot of faster cars and this was due to the haldex of the r32.
P.s trail braking is good for Fwd but not much use for 4wd
Which was kind of what I was getting at... you have to adjust your driving accordingly to the type of car you are driving. Not that most people will be tracking their daily... but the R32 is more of a GT than a chuck-it-around corners kind of car. :smiley:
Offline Ess_Three
« Reply #62 on: 12 December 2009, 11:21 »
I beg to differ...it's no use on a fixed split 4WD system...and limited use on Torsen...but on Haldex where little torque is going to the rear if the front has grip, it's ideal, and works.
My S3 was set up to be driven hard, brake hard, turn in hard, trail braking...and it didn't understeer - as long as you drove it acordingly.
Sadly, Mk4/Mk5/Mk6 platforms don't allow enogh negative camber to be dialed in to really sort out the understeer without resorting to trail braking...in my experience.
..but gaining motorcycles.
Offline Ess_Three
« Reply #63 on: 12 December 2009, 11:27 »
Two different points here...
Haldex in itself is good - not perfect - but good.
You have to learn to adapt to that, for sure, in order to get the best out of it...same in the Golf R no doubt.
R32 nose weight is something some people will always struggle with - no matter how you use it to drive the wheels.
I can't get on with them...I can't accept or drve round the understeer.
Doesn't matter whether it's a 2.8/2.9 12v or a 2.8/3.2 24v...they all do it.
It's weight and physics.
A lighter engine (2.0 TSI) with Haldex is a step forward in my book..the drive you can adapt to, with less understeer.
Win-win.
Offline R32UK
« Reply #64 on: 12 December 2009, 11:29 »
Win-win.
no doubt about that :wink: ...but is it a worthwhile swap for a V6 rumble???  :undecided:
Offline carl1
« Reply #65 on: 12 December 2009, 12:29 »
im no expert but i see what you are sayin, but isnt one of the benifts of trail braking is to shift the weight to the front to allow the front tyres to grip better in the bend allowing faster cornering, this maybe were the extra weight of the v6 may be benifcial in which the r32 just grips and grips if you can master the entrance of the corner
GTI manual PP, now sold  :-(
Offline Ess_Three
« Reply #66 on: 13 December 2009, 17:48 »
Ahh...that's the question...
Noise...or handling?
Sod the noise...
V6 doesn't sound as good as a 16v on ITBs anyway...so it's not all that!  :evil:
Offline Ess_Three
« Reply #67 on: 13 December 2009, 17:52 »
Not on a front engined car, no.
In a 911 or similar...then yes, you brake late and hard to bring the weight forward and add grip to aid turn in.
In a predominantly FWD, front engined car you hit the limit of what you can expect the front wheels to do quite quickly (braking, turning etc) so trail braking allows you to send the weight of the rear outwards - almost like trying to promote oversteer, but with no driven wheels.
You want the rear to stasrt to rotate, or come round on you, so you can grab a half turn of opposite lock (straightening the wheels) and get the power back on hard.
In my experience, more nose weight is never a good thing in a front engined car...it only ever leads to more understeer.
Offline VWKev
  • Please Support Non-Human Rights
« Reply #68 on: 13 December 2009, 17:59 »
R without a doubt if you can afford it.
GTI mk6, 3dr Manual (Yes Manual! If I wanted a Taxi I'd hail one, not spend £1500 on one), Candy White, Full Leather, Xenons, ACC, 18", RCD510 + Dynaudio, DAB Radio, Winter Pack, Luxury Pack, Fiscon Bluetooth Plus, Golf R LED's.
"Some say he drives a Shopping car, and that his car dent was actually a beauty spot....all we know is he's called Captain Failboat"
Offline R32UK
« Reply #69 on: 13 December 2009, 19:42 »
Which is why inever understood why you would want to trail brake in a AWD car. you better off getting back on the power to bring the back end round.
for what its woirth the the R32 is actually better balanced than the GTI
