Author Topic: Quick Mk2 16v Question  (Read 1696 times)
Offline drapergti
« on: 07 December 2009, 23:14 »
Hi
Does any know why a 1990 16v would have two aerial cables? is this part of the 8v/16v build maybe?
I have two at the back of the HU and terrible FM reception, which doesn't improve even if I swap them.
I have done a search and will test continuity at the weekend. I dont fancy taking my headlining down to fix it as they are a bit fragile at this age!
Thoughts?
Thanks
Offline dragonfly
Re: Quick Mk2 16v Question
« Reply #1 on: 08 December 2009, 10:51 »
There should be only one aerial (roof mounted on the 16v). If you have 2 cables then perhaps the previous didn't remove a duff one and installed a new aerial. The 16v cable has an earth as the unit is amplified.
Offline drapergti
« Reply #2 on: 08 December 2009, 14:09 »
Many thanks, is it earthed at the roof?
Offline dragonfly
« Reply #3 on: 08 December 2009, 14:50 »
Not sure - I'm sure someone will be along to confirm/deny.
Offline dubber36
« Reply #4 on: 28 December 2009, 15:05 »
It might just be the mast.
Mine is not too good, but with the mast off my 2004 Passat fitted, it works just fine.
