Author Topic: 8 gauge wiring kit  (Read 2596 times)
Offline WideBoyGTi
8 gauge wiring kit
« on: 08 October 2004, 18:06 »
Just got hold of a 2000w amp, in the manual, it says it should be run on an 8 gauge wiring kit.
Does anyone know where to get one without costing an arm & a leg??
Offline Dizzie
  • Make friends with your fast
Re: 8 gauge wiring kit
« Reply #1 on: 08 October 2004, 20:37 »
8 gauge is tiny. halfords probably sell it.
my 2x90w genesis takes 4 gauge.
Mk4 Golf 150PD
Offline WideBoyGTi
« Reply #2 on: 09 October 2004, 19:48 »
I thaught the higher the gauge the smaller the wiring kit, but i'll have a look.
Cheers Dizz
Offline Dizzie
« Reply #3 on: 09 October 2004, 20:08 »
yeah. the lower the number the phatter the cable. I wouldn't use anything less than 4 gauge now.
Mk4 Golf 150PD
Offline jasonpi
« Reply #4 on: 20 October 2004, 22:30 »
i had a 2400watt rms amp and i used 0 gauge!! bastard to fit but well worth it. forgot to mention most amps dont take 0 gauge you get a distributor block feed the 0 gauge in to it and 4 gauge will go from dis block to  ur amp if ur going for 8 gauge the wire will probbably overheat and in some cases melt depending on wattage. need any advice give us an IM
« Last Edit: 21 October 2004, 12:20 by jasonpi »
