Author Topic: dodgy top mount?  (Read 3481 times)
Offline axewielder
  • 95 dragon 8v
dodgy top mount?
« on: 23 November 2009, 13:50 »
replaced top mounts on my 8v recently as the drivers side was deffo collapsed with loadsa play when jacked up, been on a few weeks, had a look yesterday+ the drivers is still sitting alot higher than the other one, Like 6-7mm more
When replacing everything looked fine+ in good shape, is this just a dodgy top mount from gsf + a coincidence that its on the same side or should i be checking for anything more sinister, btw not being driven ATM due to exhaist+ brake pipes waiting for replacement.
Offline *tell*
Re: dodgy top mount?
« Reply #1 on: 23 November 2009, 16:41 »
i aways replace both i have gsf ones on mine.
there fine  :wink:
Offline axewielder
  • 95 dragon 8v
« Reply #2 on: 23 November 2009, 16:49 »
yeh ive done both GSF ones?
Offline filthy
« Reply #3 on: 23 November 2009, 19:12 »
my GSF top mounts are fecked after 18 months...didn't even last as long as my hottunings.... :grin:
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
« Reply #4 on: 23 November 2009, 21:35 »
Have used and can recommend the Febi ones on ebay
Offline axewielder
  • 95 dragon 8v
« Reply #5 on: 23 November 2009, 23:46 »
so you guy just rekon its a dodge one? only done a 2 mile test drive in it+ that was after id noticed it looked dodgey, rekon i can get a refund?
« Reply #6 on: 24 November 2009, 07:55 »
Worth a try  :smiley:
Offline Dan GTI
« Reply #7 on: 24 November 2009, 22:01 »
Advice I got on top-mounts is that anything other than genuine VW ones ends up being false economy. Just spend a bit extra and get gen VW mounts. Also remember to change the bearings.
Speed Bumps 1 - 0 Golf GTI
« Reply #8 on: 25 November 2009, 09:21 »
No point to be honest, the Febi ones are just as good and loads cheaper.
Offline axewielder
  • 95 dragon 8v
« Reply #9 on: 25 November 2009, 10:31 »
will probbo get some febi ones offof avs in that case  :sad:
only 7 ish quid each better than the £28 each quote i got off camberly for some 'gold plated' SKF ones, i know skf make quality stuff but come on!!
