Golf mk3
hardmonkeys
how di i get dizzy arm off??
Topic: how di i get dizzy arm off?? (Read 2619 times)
David10113
23 November 2009, 10:53 »
hi I am trying to rplace cay and arm but cant get the rotor arm off does it just pull off, on a 2.0l 16v ABF??
any advice welcome
axewielder
95 dragon 8v
Re: how di i get dizzy arm off??
23 November 2009, 11:37 »
it does on the 8v bit stiff but pulls straight up
Wayne
Sir Postalot
23 November 2009, 11:42 »
Some were glued on and you need to smash it to remove it.
Len
10k hero
23 November 2009, 11:56 »
Yea as Wayne says - mine was glued on too!
Dunno why as no problems in 5 years with not being glued.
www.sas.org.uk
www.the-ace.org.uk
David10113
23 November 2009, 12:20 »
hi guys thank you, ive been tugging at it for ages now and it just wont budge gonna have to resort to smashing it but dont wanna damage the dizzy in doing so
Len
10k hero
23 November 2009, 12:50 »
You wont damage the steel underneath!
use a chisel or a flat screw driver and chip it off is best way.
www.sas.org.uk
www.the-ace.org.uk
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #6 on:
23 November 2009, 12:52 »
get some mole grips, clamp them on the rotor arm base. that'll crush it off dead easy, then just carefully chip out whats left. dont forget to clean out the locking tab notch in the end of the shaft else the new one wont push on fully.
David10113
Reply #7 on:
23 November 2009, 12:55 »
Thanks Len!
Yep it was well and truly glued on that wasnt going anywhere, chisled it off with a flat screw driver and the trusty hammer just hope I havent damaged the spindle.
Whilst your here as you seem to have a wealth of knowledge how many vac hoses are there so I dont miss any so far i have 5 is that right? also the one that goes to the ECU i have been following the hose is the ECU in the cabin or under the black plastic cover at base of wipers somewhere?
David10113
Reply #8 on:
23 November 2009, 12:57 »
thanks rubjonny just managed to get that bit out of the locking tab, thought this would only be a 5 min job hahaha off to the get the new bit now they were due in at lunchtime i hope this has fixed my rough running problem the cap was in a very poor state
Len
10k hero
Reply #9 on:
23 November 2009, 12:59 »
The one with the wealth of knowledge is rubjonny!
Sorry never counted vac hoses! Sure there is a pic on here somewhere!
Not all mine are connected anyway coz I blanked some from airbox.
Yes ECU is up under black scuttle panel.
www.sas.org.uk
www.the-ace.org.uk
Golf mk3
hardmonkeys
