Author Topic: how di i get dizzy arm off??  (Read 2617 times)
Offline David10113
Re: how di i get dizzy arm off??
« Reply #10 on: 23 November 2009, 13:12 »
Hi len, thanks I will approach rubjonny, im still trying to sort this rough running issue, so far new plugs, new relays for fuel pump and ecu, now cap and arm but am hoping by the state of the cap and arm that will solve the problem.
then just the vac hoses to replace that dont look in that great condition
Offline Len
« Reply #11 on: 23 November 2009, 13:15 »
If after cap/rotor and then vac hoses its throttle body next!
www.sas.org.uk
www.the-ace.org.uk
« Reply #12 on: 23 November 2009, 13:32 »
The important ones are:
1x from inlet to fuel rail
1x from inlet to pcv valve (under the black cap on the front of inlet)
1x from either back of inlet (later cars) or nipple on chunky brake servo pipe (early cars) to ecu. This should be 1 meter long.
there are also vac hoses from the tbody to the carbon canister valve and I think another to the airbox, but these arnt that important. Just make sure they dont leak. Not 100% how those are routed as I've never actually worked on an ABF that's still fitted to a MK3 :grin:
Offline Paul86S2
« Reply #13 on: 23 November 2009, 13:35 »
Thick black vac line on left (with bolt in the end on photo) goes from throttle body to the charcoal canister.
Next long blue vac line goes to the airbox from throttle body.
Shorter vac line not shown goes from the air box connection to the diverter valve inside the airbox.
Blue vac line top of picture above the VW on the inlet manifold goes to the ecu under the scuttle panel on passenger side.
Short blue vac line above spark plug wire goes to the FPR.
Large black vac line not shown goes from the RH side rear of the inlet manifold to the brake servo. On some models there is a small vac line that tees off of this and runs under the battery into the front wing for the aircon.
Short blue vac line runs from the front of the manifold to the ISV.
I think thats them all.
Paul
« Last Edit: 23 November 2009, 13:37 by Paul86S2 »
Offline David10113
« Reply #14 on: 23 November 2009, 16:19 »
Hi Paul & rubjonny,
Paul thank you so much for those pics and the instructions and rubjonny i have replaced the cap and arm no change to lumpy running up to 3000 rpm then seems pretty good its just between 2,000 & 3,000 rpm that is casuing the problems.
Paul on those pics behind the airbox but just infront of the front strut mount i have a black box thing with tubes and pipes going into it someone told me its some kind of fuel evaportaion thing is that right? as I see in your pics there isnt one there??
Len yep looks like throttle body next i gave it a good dose of carb cleaner whilst in situ as havent had time to get it off today as the light is going and i dont have the luxury of a garage and im soaked!!
Still have some vac hoses to replace the ecu one and the one to the airbox i have done the others inc the little one at the front under the black plastic cover and the one that goes to the FPR,
do i need to take the throttle body off for a proper job? but it looked fairly clean before i sprayed it from what i could see
after the next little jobs (ecu vac hose & TB) im running out of ideas to what could be causing the hesitation??
« Reply #15 on: 23 November 2009, 16:24 »
yeah thats the carbon canister, there for emmissions purposes :)
Offline Len
« Reply #16 on: 23 November 2009, 16:29 »
Keep doing it in stages, finish the vac hoses then if still running rough move on to TB.
If you have to do it yes take TB off and use wet'ndry paper to give a good clean especially the area where the butterfly stops.
You'll soon see what I mean when you get it off and can see both sides.
www.sas.org.uk
www.the-ace.org.uk
Offline Paul86S2
« Reply #17 on: 23 November 2009, 16:30 »
David
The thing in front of the strut tower will be the valve for the charcoal cannister which opens to remove the fuel vapour from the petrol tank via the charcoal cannister under the air filter box. The thick black vac pipe should attach to the valve. It's not on mine because I removed it.
I would change the ecu vac pipe as your next job. If there is a leak on this it will cause symptoms like you are having. Make sure you replace it with the same length, I have read somewhere that it doesn't matter and somewhere else that it is very dependant on the length so best to be safe and replace it with the same length.
You should be able to clean the throttle body good enough with it in situ.
Paul
Offline David10113
« Reply #18 on: 23 November 2009, 17:12 »
Hi Paul / Len / rubjonny
thanks again for your invaluable advice.
I will do the ecu vac hose as soon as i can, the hose that goes to the carbon cannister is good infact it looks new.  I will make sure that the ecu hose is the same length then if no good will give the throttle body a thorough clean
Offline Len
« Reply #19 on: 24 November 2009, 10:51 »
The really important thing with the ECU hose is making sure it is clear when fitted as it has to go through a grommet. So connect TB  end first then blow through other end to ensure good passage of air. If you cant blow easily then try a bigger dia tube.
www.sas.org.uk
www.the-ace.org.uk
