Author Topic: Poorly engine!!!  (Read 3298 times)
Offline linzi
Poorly engine!!!
« on: 19 November 2009, 15:41 »
My mk4 golf 2.0 gti has been off the road for 2 weeks now. it started running slightly lumpy and there was a lag when pulling away from junctions. put new plugs and leads on - no difference.
i then put a diagnostic reader on it and it can up with lambda sensor. so replaced that, the code went but still running terrible. also changed the cat as there was a tinny rattle, it wasnt ne of the heatshields and got told it could be the cats thats collapsed thats why its running lumpy cos emissions can get out!!! it is now running worse than ever. feels like its running on 3 or even 2. no power in it at all!!!!! had it at a garage and they think its sumthing to do with the pistons as its been using quite alot of oil and the new spark plugs are covered in oil. just put diagnostic on it again and it is coming up with:
  • multiple misfire detected
  • misfire in cylinder 1
  • misfire in cylinder 2
  • misfire in cylinder 3
Anyone else had the same and what was the outcome. thanks   :undecided:[/list]
Offline jonnyturbo
Re: Poorly engine!!!
« Reply #1 on: 19 November 2009, 15:46 »
Coil packs?
Offline linzi
« Reply #2 on: 19 November 2009, 16:00 »
Gonna have a dumb moment here!!! where is that?? :rolleyes:
Offline linzi
« Reply #3 on: 19 November 2009, 16:06 »
Its ok dumb moment over!!!
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #4 on: 19 November 2009, 16:32 »
you found them then  :grin:
2000 Mkiv GTi 1.8T AGU
Offline Rhyso
« Reply #5 on: 19 November 2009, 16:38 »
it isn't it? the 2.0 only has one coil does it not?  :undecided:
Offline linzi
« Reply #6 on: 19 November 2009, 16:42 »
it does only have one yes. we tried a coil pack from a 1.6 we have got in the garage and it didnt seem to make a difference but im thinking its not the same as the 2.0 one anyway.
Every time it gets started it runs rougher and rougher each time
  • "1.8T AGU"
« Reply #7 on: 19 November 2009, 16:44 »
it does rhys iirc
so will have seperate ht leads
Offline dai-cymru
  • 1989 MK2 16V
« Reply #8 on: 19 November 2009, 16:45 »
not if it's a azj engine code  :smug:
Offline linzi
« Reply #9 on: 19 November 2009, 16:47 »
its AQY! :wink:
