Author Topic: Poorly engine!!!  (Read 3312 times)
Offline dai-cymru
  • 1989 MK2 16V
Re: Poorly engine!!!
« Reply #10 on: 19 November 2009, 16:49 »
Has anyone checked the head gasket
Offline linzi
« Reply #11 on: 19 November 2009, 16:51 »
not sure. think the garage did a compression test on it and all 4 were down slightly.
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #12 on: 19 November 2009, 16:55 »
replacement coil pack is 032 905106 B for your AQY code and the ignition leads set x4 is 06A 905 409 L hope that helps if you need these  :wink:
2000 Mkiv GTi 1.8T AGU
Offline dai-cymru
  • 1989 MK2 16V
« Reply #13 on: 19 November 2009, 16:57 »
If it was down on compression could be the rings passing or head gasket fault, If it's in a garage i would have expected them to have checked the head anyway.  :undecided:
Offline linzi
« Reply #14 on: 19 November 2009, 17:01 »
they thought it mite of been the rings, thats why its using alot of oil and the spark plugs have oil on them. the garage didnt really do much apart from look for a rattle for 2 hours that they still couldnt find, thats why its parked outside my house again!!!
Gonna get my hubby to take the head off and have a look cos i have got a friend wiv an engine workshop and he will do all the internal stuff for me if it needs it.
  • "1.8T AGU"
« Reply #15 on: 19 November 2009, 17:01 »
i would have thought so also and at least checked your coolant bottle to see if theres oil mixed with the water and checked your oil level this would show up mayonaising on the dipstick which would give you the likelyhood of a failing h/g if the compressions are down equally on all four cylinders or just one or two  :undecided:
Offline linzi
« Reply #16 on: 19 November 2009, 17:04 »
my oil and water appear fine. i will get him to investigate at the weekend!!!
i hate not having a car!  :angry:
