Author Topic: INDECATOR RELAY BUZZING  (Read 1871 times)
Offline seamud
« on: 17 November 2009, 22:18 »
can any one help me coz this is doing my foookin head in
my indecator relay (21) buzzs when ignition on when i use  indecator buzzing stops tried changing stalks and relay
which ant helped
also got no power to window wipers not sure if this would be linked in any way??
got k2 golf vr6 lump with mk3 fuse box
Re: INDECATOR RELAY BUZZING
« Reply #1 on: 18 November 2009, 08:55 »
disconnect the wiper stalk and see if the buzzing stops, if it does I'd say its the stalks at fault. might just be a loose connection to the stalks, make sure they're all plugged in fully.
Offline seamud
« Reply #2 on: 18 November 2009, 23:49 »
the buzzing stops when i disconnect changed stalks still the same
also got no power to window wipers could it be related in any way
« Reply #3 on: 19 November 2009, 11:27 »
check the wiring from the stalks down to the fusebox, sounds liek a dody wire. if one loom has melted could explain why the wipers have packed in as well.  luckily all the stalk loom is all seperate so dead easy to swap if it has melted :)
Offline seamud
« Reply #4 on: 19 November 2009, 19:28 »
iv found problem to buzzing relay seems to be from clocks
found out what was indector light and cut wire from clocks and stopped buzzing
and indectors working. still hasnt solved wiper issue tho. checked wires no splits
loose ones
cant see it being clocks casuing this or am i missing something
« Reply #5 on: 20 November 2009, 10:56 »
hmm, check fuse #5, and have a look in the scuttle area, make sure wiring to wiper motor is ok
Offline Diamond Hell
  • Opinions я Us
« Reply #6 on: 21 November 2009, 08:33 »
Errr, there's a buzzer in the clocks, which could well be buzzing either if you're down on pressure on the engine (which is when it's supposed to go off) or if there's a fault in the clocks it could go off.
More likely that than a relay bu the sounds of it.
