Author Topic: pedal rubbers  (Read 3008 times)
Offline leeroy20vt
  • h reg mk2 gti
pedal rubbers
« on: 16 November 2009, 19:40 »
as per title i would like to put new pedal rubbers on my mk2
i know on the mk4 golf u can put the audi tt pedals and look quite nice
so what can u put on the mk2 thats a direct fit
cheers
Offline Mew
Re: pedal rubbers
« Reply #1 on: 16 November 2009, 19:42 »
I'm sure i've read that the TT pedals can be fitted to the mk2 :undecided:
Offline leeroy20vt
  • h reg mk2 gti
Re: pedal rubbers
« Reply #2 on: 16 November 2009, 19:46 »
be intresting to find out i did search but couldnt find any think  :embarassed:
Re: pedal rubbers
« Reply #3 on: 17 November 2009, 10:21 »
you need a LHD TT accellerator pedal, and the RHD brake/clutch pedals. one of the pedals needs a bit trimming off to fit, you'll see what I mean. you can use 2 clutch pedals instead, but the tabs that stop your feet slipping under the pedals wont be in the right spot.
Offline leeroy20vt
  • h reg mk2 gti
Re: pedal rubbers
« Reply #4 on: 17 November 2009, 16:45 »
cheers now will i find a lhd tt pedal lol
Offline Horney
Re: pedal rubbers
« Reply #5 on: 17 November 2009, 16:48 »
Peddle rubbers? Skateboard grip tape FTW!
nick
Offline wil0
Re: pedal rubbers
« Reply #6 on: 18 November 2009, 00:21 »
then you have to wear skate shoes? ;)
3Door Oak Green 91 MK2 16v GTi
Offline Sam
  • Sam I am
Re: pedal rubbers
« Reply #7 on: 18 November 2009, 00:23 »
nick
Boom!
And f**king Boom!
These requirements are where its at!
« Last Edit: 18 November 2009, 00:26 by caistor_bmx »
Offline dragonfly
Re: pedal rubbers
« Reply #8 on: 18 November 2009, 11:11 »
I had a set of TT pedals on my old Golf all for rhd. The brake pedal has a rubber piece that goes thorugh the pedal to hold it into place. The Golf pedal doesn't have a hole through it so if you remove the rubber piece you need to secure it to the pedal another way otherwise it will slip off.
A mk1 Octavia vRS has the same pedal covers as a TT.
Re: pedal rubbers
« Reply #9 on: 18 November 2009, 11:33 »
ah, i thought the brake pedal still had the lip round the outside. 2x clutch pedal rubbers would be easiest then :)
