Author Topic: pedal rubbers  (Read 3034 times)
Offline wil0
Re: pedal rubbers
« Reply #10 on: 18 November 2009, 11:52 »
so can you get tt or vrs rubbers and put them on mk2 pedals?
3Door Oak Green 91 MK2 16v GTi
Re: pedal rubbers
« Reply #11 on: 18 November 2009, 12:51 »
Yep.
I think you can fit MK4 R32 pedals too, same applies with the LHD accelerator cover and 2x clutch rubbers I believe?
Offline dragonfly
Re: pedal rubbers
« Reply #12 on: 18 November 2009, 15:12 »
ah, i thought the brake pedal still had the lip round the outside. 2x clutch pedal rubbers would be easiest then :)
The lip is actually around the side and bottom, hence why it can slip off when used on the Golf. They do look nice though.
Re: pedal rubbers
« Reply #13 on: 18 November 2009, 16:07 »
ah so not all the way round the edge then?  the clutch pedal will fit both mk2 pedals fine, just as i say the extention bit that stops your foot slipping under the pedal will be on the wrong side. No big deal, not like the oem MK2 pedals have these!
Offline Mr Blue
Re: pedal rubbers
« Reply #14 on: 18 November 2009, 18:19 »
Im not a fan of TT pedals on old skool golfs. They look well out of place.
I think you use the mk1 black pedal rubber for the accelerator
« Last Edit: 18 November 2009, 21:12 by Mr Blue »
Offline nealey
Re: pedal rubbers
« Reply #15 on: 18 November 2009, 20:56 »
I think you use the mk1 black pedal rubber for the accelorator
I used a mk3 tdi accelerator pedal rubber on mine, fits perfectly!
Offline Ben Lessani
Re: pedal rubbers
« Reply #16 on: 18 November 2009, 21:25 »
How on earth did you get the MK3 kit to fit?
Its a totally different shape to the mk2 :laugh:
Offline weazgti
Re: pedal rubbers
« Reply #17 on: 18 November 2009, 21:51 »
 :grin:
