Author Topic: Strong Fuel smell inside....urgent help needed!!!  (Read 22585 times)
Offline gor131-x
« on: 07 November 2009, 17:00 »
Ive been getting a really strong smell of raw unburnt fuel inside th car,yesterday it got so bad that i had to pull over,switch car off,open all doors and stand outside until it was breathable.
 any idea what it could be,ive bought oil filter,fuel filter spark plugs and oil to get it serviced but i want to sort this problem out, if any before i do the service.
oh and the fuel economy is crap,20 quid gets me just about to a 100 miles
ive had a look at the engine and i noticed a pipe disconnected,what is this?
and also i did a search and some guys said the coolant sensor is a blue type thing at the front,i havent gota   blue one,ive got a yellow one and a blank,is that right?
car is a 1.4 AEX engine code
Pics
whats this?the pic is from under the airbox at the back and has it got anything to do   with my fuel smell problem?
and is this suppsoed to have a blank next to the yellow sensor (by the way,whats that one for?)
any help appreciated and im not driving the car until this smell is sorted,
thanks
gtigolfthree
Re: Strong Fuel smell inside....urgent help needed!!!
« Reply #1 on: 07 November 2009, 17:15 »
Fuel leak some where.
Offline Mikester
  • Civic Type R
« Reply #2 on: 07 November 2009, 19:04 »
Genius.
You are a genuis.
Are you experiencing any running issues? Along with the smell?
Offline gor131-x
« Reply #3 on: 07 November 2009, 20:08 »
yeah i figured that part out :shocked:
it runs fine,the idle sits at 600rpm and you have to give it a bit of throttle before setting off or you'll just stall it but it is only a 1.4 so im thinking thats normal
apart from that,its drinking a lot,like i said,i put in £20 and im on 82 miles and im halfway into reserve
gtigolfthree
« Reply #4 on: 07 November 2009, 20:24 »
 :laugh: :laugh: You need to follow your fuel line from the tank to the engine and find that leak and be carefull petrol is really dodgy stuff. Sorry you already know that.  :grin:
Offline justalex81
« Reply #5 on: 07 November 2009, 20:26 »
if you have difficulty seeing then use a lighter. Make sure you hold it close to your face to get the most visibility  :grin:
Offline AudiA8Quattro
« Reply #6 on: 07 November 2009, 23:13 »
Is that pipe in the first pic a crankcase breather pipe?
Split or disconnected crankcase ventilation hoses can cause fuel smells in the cabin.
« Reply #7 on: 07 November 2009, 23:15 »
Long shot but maybe the tank sender seal has let go.
Offline shepgti
« Reply #8 on: 07 November 2009, 23:41 »
agree, sort that busted pipe out and see if it still smells
Offline davero
« Reply #9 on: 08 November 2009, 00:00 »
As mentioned before, this is your most likely culprit, in my experience, the mark3 is very sensitive to breathing issues, replace this hose and take it from there.
