right guys,ive changed the oil,oil filter,fuel filter and spark plugs,.
i thought i'd change the thermostat,when i opened the hose,the pin was there but the rest of the thermostat was not to be seen! so i fitted a new thermostat and literally an hour or so after changing it,the car started overheating. its been a few days and now its too bad to drive,
a few questions:
1. can the thermostat only go in one way? ive put the pin of the thermostat into the flange connected to the radiator hose
2. without sounding stupid,is the thermostat faulty? even though the car didnt have one before!
3. when i open the header tank,all the water expels out of that,and there are big bubbles,does that mean head gasket gone?
4.the possible options ive read up on are water pump failure,radiator blocked,thermostat or headgasket.any other possibilities?
im checking the thermostat now with the boiling water test in a pan to see if thats faulty or not,will keep you posted!
thanks
