Author Topic: rough starting.  (Read 14237 times)
Offline Rhyso
Re: rough starting.
« Reply #20 on: 16 November 2009, 09:53 »
I think I stress myself out too much with noises on the car.
Yes. Yes you do  :tongue:
Offline asif
Re: rough starting.
« Reply #21 on: 16 November 2009, 10:33 »
You already noticed that in the short space i've known you on this forum lol
MK7 GT Bluemotion Tech TDi 150
Offline MK3TDi1996
Re: rough starting.
« Reply #22 on: 17 November 2009, 08:32 »
RE noise stops when you dip the clutch = thrust bearing, no big deal :)
Offline asif
Re: rough starting.
« Reply #23 on: 17 November 2009, 10:07 »
MK3TDI1996 cheers for that info mate, it doesn't have a knock on effect does it, like if I don't get it changed.
Expensive to get replaced? I bet if it's near the clutch it'd cost a bomb in labour.
Offline Rhyso
Re: rough starting.
« Reply #24 on: 17 November 2009, 10:10 »
its just gets progressively noisier I believe
And yes if you do change it you just as well replace the flywheel / clutch whilst you're there as it will cost roughly the same in labour
The part itself is only £40 or so from the dealers
Offline asif
Re: rough starting.
« Reply #25 on: 17 November 2009, 10:49 »
If me or my brother knew this at the time when the flywheel and clutch got replaced it would've been really handy, never mind if it doesn't have a knock on efect and not a big problem i'll just leave it.
It's not the type of thing that if I don't get it fixed it'll fook my flywheel or clutch up will it?
Offline MK3TDi1996
Re: rough starting.
« Reply #26 on: 17 November 2009, 14:48 »
In my own experience, a noisy thrust bearing has never been more of a problem than the irritating noise it makes.  I've only ever replaced one flywheel and it was a G60 one to replace my standard 1.9tdi wheel.  Not that i'm questioning anyone else's experience with them of course!
Replacing the thrust bearing is a pretty easy job to do yourself if it's bothering you that much.  I'd just wait till your clutch gives up though :) - seeing as you seem to have done it quite recently, that could be a while :p
Offline mf44
Re: rough starting.
« Reply #27 on: 28 November 2009, 15:34 »
how do,
You've changed the plugs right?  If they are fairly new (or you have tested them working) then have a look at your glow plug relay....
Anyone know which relay is for the glow plugs?
Offline MK3TDi1996
Re: rough starting.
« Reply #28 on: 28 November 2009, 18:19 »
how do,
http://www.vwaudiforum.co.uk/forum/showthread.php?t=50515
Offline mf44
Re: rough starting.
« Reply #29 on: 28 November 2009, 19:10 »
how do,
Thanks! Spent so long trying to find this out!!
